Meter dropped to 0 but charger is humming
SOURCE: Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
Posted on Apr 26, 2009
SOURCE: When Charging a battery with charger do you set it
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
Posted on Jun 01, 2010
SOURCE: HAVE NO IDEA HOW TO
The meter is telling you approximately how much current (amps) it is sending to the battery. When the meter moves all of the way to the right it is charging as hard as it can (that would be 6 Amps) which indicates that the battery needs a lot of charging. As the battery becomes saturated with charge, the meter will move toward the left. As the battery become charged, the unit automatically tapers off the current. The meter can indicate as little as little as zero Amps, meaning it is not charging the battery at all - which is the case when the battery is powered up, but isn't even connected to the battery. If it reads zero when it's connected to the battery, the battery is broken and can't be charged.
Since this charger is rated at 6 amps, it will indicate about 3 amps when the battery is about done. It won't normally go to zero because those 3 amps are getting wasted just heating up the battery.
Posted on Aug 16, 2010
Dec 17, 2017 | Health & Beauty
Mar 01, 2016 | Schumacher SE82-6 Manual Charger...
Sep 04, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Jan 07, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Dec 20, 2010 | Schumacher & Fast Charge Starter Charger
Aug 16, 2010 | Schumacher & Fast Charge Starter Charger
Nov 13, 2009 | Schumacher & Fast Charge Starter Charger
Oct 21, 2009 | Schumacher & Fast Charge Starter Charger
Apr 26, 2009 | Jeep Grand Cherokee Cars & Trucks
Feb 02, 2009 | Schumacher & Fast Charge Starter Charger
Feb 20, 2021 | The Health & Beauty
42 people viewed this question
