Question about Crosley Washing Machines
I have crosley washer model # BYCW4271WO and agitator not working.
It's a 4 cycle 2 speed washer. Everything else seems to work except agitator not spinning.
Posted by David Triplett on
5 Related Answers
Anonymous
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: WASHER WON'T SPIN OR AGITATE
hi sorry i, not familiar with that make
Posted on Oct 05, 2008
Robert Siegel
  • 36 Answers
SOURCE: maytag washer won't agitate
your transmission is no good and needs to be replaced
Posted on Jan 02, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: washer no longer spins.
with the washer set for spin and turned on...raise and lower the lid.
If it spins replace the timer.
If it does not spin...replace the direct drive coupling on the motor.
Posted on Mar 11, 2009
Frank
  • 90 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Agitator: bottom moves, top does not
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Crosley Washing Machines Experts
peter gittos
peter gittos
Michael Thomas
Michael Thomas
jdthefixer
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
