Question about Hayward Pool & Spa
Hayward H Series Natural Gas Swimming Pool Heater repair manual
Posted by rene casault on
Frank Walton
  • 26 Answers
Contact the manufacturer or a dealer
Posted on Jun 09, 2019
5 Related Answers
john224
John Prohaska
  • 1378 Answers
SOURCE: Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
Posted on Jun 14, 2009
thepool
thepool
  • 78 Answers
SOURCE: Hayward pool heater wont stay lit
Follow the troubleshooting guide on page 36 of this owners manual. It will walk you through problem solving... http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Posted on Apr 22, 2010
Anonymous
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
Anonymous
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
bshann977
SOURCE: Hayward H 300 series pool
I have an H300 Millivolt Hayward heater. It will start and run for about 1 minute then shuts off along with the pilot going out. I've tried cleaning all the terminals and running all new wiring but same result. I've also jumped out the TH to TH terminals leaving the jumper in place and it still shuts down after 1 minute. Any idea what that could be ?
Posted on Jun 27, 2011
Hayward H series propane pool heater, how do I convert to gas?.
I used to be able to get it through my supplier but the link is now dead and shows product not available. I am sure you can get this through Hayward direct. The last kit I bought was around $200 (my cost, not retail). As for a used kit, I seriously doubt that is an option.
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Heater error message ac
I found this on EBAY and it looks like a great cheaper way to replace the bad keypad. The product has received fantastic reviews. here is the link:http://www.ebay.com/itm/Hayward-H-Series-Pool-Heater-Bezel-Keypad-for-most-Hayward-control-panels-/281197994622?pt=LH_DefaultDomain_0&hash=item4178b4e27e#ht_1092wt_922
Nov 09, 2013 | Hayward 400fdn Low Nox Nat Gas Swimming...
Hayward pool heater model h100d1 ignites with a bang and goes out
I had the same problem. It was my igniter. It was all corroded and oxidized. Would not properly ignite the gas fast enough and when it finally ignited, the excess gas in the chamber would explode and put out the flame and cycle over and over with bang. Took igniter out, cleaned and filed down the copper prongs. Replaced and all was well.
Jun 06, 2012 | Hayward Gas Swimming Pool Heater 100k Btu...
Solenoid Valve where the natural gas line connects to the Heater keeps turning on and off at a rapid pace. The valve only stays off about a 1/2 second and may stay on for 10 seconds before it goes...
You can find a Hayward warranty service provider in your area by entering your zip code and selecting "product repair or service" on Hayward's locator page of their website, found here:
http://www.haywardnet.com/locator/
John
Sep 16, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
I have a Hayward H100IH pool heater. With the pool filter on the heater starts to heat up when I turn up the thermostat, but the heat turns off after a few seconds.
That doesn't sound fun. You could call the Hayward technical support number at 908-355-7995 and they might be able to figure this out. I hope this helps.
Please vote for this answer. Thank you.
Aug 23, 2011 | Hayward Gas Swimming Pool Heater 100k Btu...
Pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Jul 21, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
136 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
