Televison & Video Logo
A
Anonymous Posted on Jun 09, 2019
What is meaning of deffirent modes in remote - Televison & Video
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Jun 10, 2019
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
566882
Points
3788
The sun symbol is heating, an icicle is cooling, the fan symbol means fan only. A triangle means auto mode, the machine will heat or cool to get the temperature you have selected. Looking at your remote, it is set on 16 degrees cooling. The large fan symbol will mean its on high fan speed.
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Display says it is stuck on dvd 2 cannot program the dvd recorder to record
DVD recorder stuck on DVD 2 mode that means you can no longer operate it with its remote, right?
Now you need to change remote mode to DVD 2 so recorder can receive its signals.
Slide down lower cover of remote and set Command Mode switch to DVD 2 position, now your recorder will get remote signals and you can operate it properly.
Thanks.
2helpful
How do i set up my nikon d500 to use my nikon ml-l3 remote controller
I assume you mean either the D50 or the D5000.
In either case, set the camera's shooting mode to one of the two remote modes. Quick-response remote mode fires the shutter when you press the button on the remote. Delayed remote mode waits two seconds for you to hide your hand behind your back before firing the shutter.
2helpful
Where is the fuel pump relay located in a 1994 Pontiac Grand Am 4 cylinder 2.3 quad engine?
ususally in the fuse block on the engine conpartment, youll see it. or it deffirence like in 3 years on models there running loose by the firewall. hope this helps
Safe mode? what does that mean?
This means that the firmware on your remote needs to be updated. Please do the following:
1- Launch the software and log in to your account.
2- Click on 'Downloads' at the top of the screen.
3- Click 'Firmware' and follow the steps to update the firmware on the remote.
4- Update your remote.
What does it mean when the screen on the remote says "safe mode!"?
Hi. Safe mode means that you need to update the firmware on the remote.
1. Launch the software and log in.
2. Click 'Downloads' at the top.
3. Click 'Firmware'.
4. Update the remote.
Hope that helps :)
1helpful
HOW TO USE P6000 REMOTE SHUTTER RELEASE
Do you mean the ML-L3 remote? Set the camera's release mode to one of the remote modes. Look up "Shooting Mode" or "Release Mode" in the camera manual.
1helpful
CANT LOAD WEB SETTINGS
if you contact your network provider they will mms the settings to your phone, it should then auto setup.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
