Question about Sharp Office Equipment & Supplies
Sharp ar5516 isn't working properly seeing code is L1 please tell me the trouble shoot out
Posted by Tapank Paul on
5 Related Answers
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Code
how input code(# interrupt C interrupt)
Posted on May 30, 2010
sree jj
  • 31 Answers
SOURCE: my sharp ar5516 use to
For H4 enter the following codes # interrupt C interrupt 14 Start button twice For ch check whether all the doors(side door,front door) are closed.
Posted on Jan 16, 2011
SOURCE: how to enter in simulation
perform the following procedure to enter the simulation mode :-
press " # " key >> " Interrupt " key >> " c " key >> " Interrupt " key >> " 42 " >> " start" >> " 1" >> "start" ( this to reset the the drum indicator and replace 42 by 20 to reset the maintenance indicator).
I hope this help
Posted on Feb 17, 2011
phal
SOURCE: sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Posted on Dec 14, 2011
sree jj
  • 31 Answers
SOURCE: my sharp ar5516 is showing L1 Error what can i do
it must be laser problem.Pls clean the laser unit to solve it
Posted on Jan 03, 2012
My copier sharp-ar5516 is indicating error code F5 00 what's problem
on your ar5516 f5 error code would be a copy lamp problem, lamp bad or the fuse or a connection.
Apr 11, 2017 | Sharp Office Equipment & Supplies
Error F2 on Sharp AR5516
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
May 09, 2014 | Sharp Office Equipment & Supplies
Sharp ar5516 error e7
with such error displayed press the print button, the machine shows another sub code, if it is 11 or 12 means a trouble with the scanner section.
to fix take out the glass ,clean the white strip left, the lamp reflector and mirrors, open the lens cover (5) screws, clean the lens and CCD.
if the subcode is 16 a trouble with laser
Nov 18, 2011 | Sharp Office Equipment & Supplies
Sharp ar5516 f2 error
Nov 14, 2011 | Office Equipment & Supplies
My sharp ar5516 use to display h4, l1, h1, p1, u1, ch and i need the solutions to open them.
Jan 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have 3 sharp printers arm160 and have 2 errors. Ch & L1 adn anyone tell me what they mean? Thanks
ch-
1.side door open
2.developing cartridge not installed
L1-
scanner feed trouble
May 15, 2010 | Sharp AR-M160 Laser Printer
L1-18 code
I don't see a reference to a L1-18. A L1 code is a scanner feed problem. I only show a L1-00 code. Sorry.
Jul 01, 2009 | Sharp AR-507 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
