Question about Russell Hobbs Irons
Hi I have a Russell Hobbs iron and it’s just switched off, I’ve tried the auto shut off procedures and the lights come on but the procedure to reset it don’t work.. any ideas ??
5 Related Answers
smilemaker
Kanth raj
  • 790 Answers
SOURCE: Faulty Russell Hobbs Steam Iron
http://www.ehow.com/how_2067318_fix-nonelectric-steam-iron.html
Posted on Jan 01, 2008
Anonymous
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
Anonymous
  • 137 Answers
SOURCE: lost instructions on how to use self clean on my iron
It probably needs to be de-calicified, you can find the stuff to do it at most any hardware store.
Posted on Mar 28, 2009
Anonymous
  • 67 Answers
SOURCE: digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Posted on Aug 04, 2009
Anonymous
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
Hi. I have Russell Hobbs iron not getting hot but the power light is coming on but the iron not getting hot
Check may be the wire cable is cut off inside or cut off from the iron.. Be careful it could be bridging issue or the elements are no more in contact get in touch with the repairers
Apr 26, 2018 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
Iron switches on but does not heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 07, 2010 | Russell Hobbs 12236 Iron with Auto Shutoff
Irons Logo
206 people viewed this question
Top Russell Hobbs Irons Experts
NOEL
NOEL
Harrie
john h
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
