Question about Electrical Supplies
I have a 2002 inboard Tige. I have no power to the dashboard. I bypassed the 50 amp circuit breaker with no results. Any ideas?
Posted by Ruth Ludlow on
Carl Rock
  • Electrical S... Master
  • 2,275 Answers
I have a 2002 inboard Tige.  I have no power to th - t1-lvjzafi0j1uern1nx1g5lye1-5-0.png
Posted on Jun 09, 2019
5 Related Answers
Anonymous
  • 76 Answers
SOURCE: power windows and blower motor
check for inline fuses. wire that will melt if theres to many amps running through it usually under the hood. hope this helps
Posted on Nov 06, 2008
Anonymous
  • 700 Answers
SOURCE: 3-pole 60 Amp Circuit Breaker is tripped and won't reset.
check ot see if its on a shunt trip system. what it means is that in order to reset the breaker you have to see what made it trip. Look for a 115 volt breaker that is tripped in the panel that serves tha line. good luck.
Posted on Jan 25, 2009
Anonymous
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: I have 60 amp circuit breaker on my electrical a/c
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Posted on Dec 07, 2009
Testimonial: "Thank a lot this was very helpful"
Anonymous
  • 145 Answers
SOURCE: Can't find any ite bl circuit breakers.
YOU CAN CALL ITE FOR A DEALER NEAR YOU
Posted on Jan 08, 2010
What fuse operates the rear power wundows on 2002 stratus?
It's not a separate fuse (or circuit breaker) than the other windows. Only one power source for all power windows. Usually it is not a fuse, but a circuit breaker in the fuse panel under the dash. If fronts work but not the rear windows, look for broken wires in the small harnesses going to each door, including the driver's door.
Apr 26, 2018 | Cars & Trucks
A 60 Amp breaker (three phase) powers an 125 amp main lug 3 phase panel is that k or do i need a bigger braker. the wires are #8 THHN.
The breaker that feeds the panel and the wire are what determines the rating. The panel has to be at least as high as the breaker. It can be more, and no problem.The problem I see is that the wiring is undersized for the 60 amp breaker. You should have #6 wires or change the breaker to a 50 amp. If that is not enough for your load, you must change the wiring. It also depends on the type of wire. THHN will have the largest amperage, but if it is TW, it will be lower. Rule of thumb would be #10-30 amp, #8-40-50 amp, #6-50-60 amp, #4-70-90 amp and #2-95-135 amp. There are other factors, such as derating etc. but if you wanted to increase to 100 amp, I would run #2 thhn. Hope this helps.
Mar 05, 2011 | Siemens Murray 125 Amp Circuit Breaker...
While welding aluminum in AC mode (with continuous high frequency), the 50 amp circuit breaker in the house emits a loud buzzing. The machine is electrically grounded to a 8 foot grounding rod. Anny...
The machine is probably taxing the capacity of the power circuit and it's breakers. While the machine may be pulling less than 50 amps average, the high frequency modulation is likely producing peaks over 50 amps. Changing out the 50 amp breakers might help and again may not. The whole circuit should be rated at least 25% over expected current draw. The grounding system is to protect you, not the machine. Good luck!
Dec 14, 2010 | Garden
We had a power surge now when i plug my fridge in it blows my circuit breaker
The power surge might have damaged the wiring to the refrigerator. You can check this one with a megar. That is only if the circuit breaker blows off, ONLY when the unit is turned on. Else, the problem may be that current is flowing through the neutral. You can check it with a tester and if so, report it to the electricity board. Else, as a temporary measure, you can connect your unit, bypassing the circuit breaker. But in that case the circuit breaker will never blow off regarding any complaints to the unit and may result in a slight power wastage.
Jul 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
Can Federal Pacific ni breakers be used in place of nc?
I honestly wouldn't recommend using Federal Pacific in the place of anything. If you go to your local home store they may be able to help you out with a solution of what breaker to use. Federal pacific is being removed from any old construction where its found because Federal Pacific breakers are many times faulty and don't trip when they should resulting in a fire.
Apr 11, 2010 | Pacific Industrial Federal Pacific 50 Amp...
Which fuse on the fuse panel is the one for the power windows i lost the manual
I know thta, for a 2002 Ford Explorer, the 30 amp circuit breaker in location #62 of the power distribution box in the engine compartment is the power window circuit breaker. (unfortunately in the 2002 owner's manuals it is labelled accessory delay ) later years are labelled as the power window circuit breaker.
Hope helped with this. Remember rated this help, good luck.
Nov 24, 2009 | 2003 Ford Explorer
Circut Breaker Trips
If the fault were with the product, the breaker would trip right away. You have either a poor electrical connection (power supply) or a weak or undersized circuit breaker. Free standing ranges usually use a 50 amp double pole breaker. Check electrical connections at breaker, range recepticle, and power cord to range to make sure all are tight. (obviously, have breaker off when making these checks)
Nov 23, 2009 | Refrigerators
Gfci breaker for spa
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Electrical Supplies Logo
114 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
