The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Posted on Apr 29, 2016
you can purchase same model or new model here>> Procellular Services News Reviews and Deals Online
Posted on Aug 01, 2018
"The Igloo 100 series portable icemakers that are sold all over for about $100 have several minor issues. For ADD WATER light, there are 2 main ones. The water SENSOR is located at the top right of the unit. Remove the BACK cover with 6 screws on the bottom. Remove the TOP assy with 4 screws from inside the case. When the TOP is off, facing the unit from front, you see the small silver wire at the back right. Clean it AND the screw visible thru the hole in the plastic at the end of the sensor wire. The screw is the GROUND side of the sensor. This fixes many of the issues. But the SENSOR senses water FLOW, not water LEVEL. If the PUMP is not moving water, the sensor assumes you are OUT of water and turns on the ADD WATER light. The pump apparently burns out easily. Remove the PUMP wire connector from the CONTROL BOARD and check for continuity in the motor. Be sure your multimeter leads actually touch the connectors. The connection end is too small for most meters, so probe from the backside of the connector. If motor is good, check for 12vdc at the board side of the pump connector. Plug in, turn on. Should be 12vdc within 45 seconds. See, the water pump comes on first. When water is moving over the sensor, then the board will turn on the compressor and start freezing. "
Posted on Aug 27, 2018
SOURCE: igloo ice maker won't make ice. what's wrong?
Water valve possibly defective
Posted on Oct 09, 2018
SOURCE: Do I use distilled water in igloo ice maker
generally you would use mineral water but it depends on the model you are using see here for more infomation https://homefixworld.com/igloo-water-cool-and-dispenser-with-ice-maker-review
Posted on Mar 03, 2019
Apr 29, 2016 | Freezers
Mar 07, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Sep 07, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
Mar 19, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Mar 20, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
1,535 people viewed this question
