Question about Locks & Locksmithing
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
Posted on Aug 19, 2009
SOURCE: I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Posted on Nov 15, 2009
Dec 03, 2017 | The Computers & Internet
Jan 25, 2017 | Home Security
I had the same problem.
Call Harbor Freight Customer Service @ 1-800-444-3353
Before you call the number though, go to your safe and write down the three or four digit key code, that is on the silver key slot. (they will need that number)
It is something like $8.00 per key, plus shipping, and it will take about 2-3 weeks to get it, but they will mail you the keys in a small brown envelope.
Good Luck!
Feb 27, 2013 | Check Point Network Adapter
1-800-444-3353. They are distributed by Harbor Freight. This may be their phone number. In any case, they have technical info.
http://manuals.harborfreight.com/manuals/45000-45999/45891.pdf
This is the manual.
Gary
Aug 12, 2011 | Vacuums
Nov 15, 2009 | Sentry Fireproof Safe
Nov 02, 2009 | Check Point Network Adapter
Aug 06, 2009 | Check Point Network Adapter
159 people viewed this question
