Question about Kenmore Dryers
My kenmore elite cooktop "red dashes" on all heating elements Tried to depress lock for 10 seconds, nothing....no heat
Posted by Carole Whitcher on
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
Posted on May 20, 2008
Anonymous
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
Anonymous
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: How do you replace the heating element on kenmore
Have you confirmed the heating element is bad? There's more to the dryer heating circuits that can cause a no heat problem besides the heating element.
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare.
Now...if you have determined the heating element is definitely bad, and this is a Kenmore Elite as the one you posted this question under, the following link explains how to access the heating element and replace it: http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Posted on Jan 06, 2010
aasc
Mike Smith
  • 1606 Answers
SOURCE: kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Posted on Apr 28, 2010
How do I unlock the cooktops on Kenmore Elite Electric Range model #C970-440935
Clear the lock mechanism -- as indicated by the DOOR LOC light -- by pressing and holding in the oven door light switch for 20 to 30 seconds. While the switch is depressed, the latch motor will gradually withdraw the lock, allowing you to open your oven door.
1helpful
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
2answers
The red light is on above the dacor name but nothing will go on.
this may be due to your child lock function, depress lock function(for whatever use and care manual says) and it may release to open functions.
2helpful
Kenmore elite elec dryer, 110.64972300. runs no heat
Kenmore electric cooktop not working on low eat
If it was the burner element it either would work or not (no in between)
It has to be the switch
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3 of 4 heating elements on Kenmore glass cooktop do not heat properly. They come on and then cycle off and on and never reach a cooking temperature. Only one of the 4 works properly. I believe the...
this might be normal behavior is the unit still heating and boiling items? has the unit worked differently in the past?
see below
Why the smoothtop radiant cooktop element cycles on and off
  1. Save as PDF
  2. Share
Table of contents
Does the radiant heating element cycle on and off?
  • The surface cooking area may glow red when a heating element is ON.
  • Some parts of the surface cooking area may not glow red when a heating element is ON.
  • The warming zone element (on certain models) will not glow red.
  • Radiant elements have a limiter that allows the element to cycle ON and OFF, even at the HI setting, to prevent damage to the ceramic cooktop. This is normal operation.
  • The radiant heating element retains enough heat when off to provide a uniform and consistent heat. The surface will still be hot even though the element has cycled OFF.
  • Cycling at the HI setting is normal and can occu
14helpful
My Kenmore Range had theoven and stovetop locked symbol on it how do i unlock it
Either hold down the 'Unlock' button or if the little red pad lock symbol is lid in the main display hold the 'Oven light' button for about 7 seconds...
1helpful
Kenmore elite dishwasher model 665,15979992 remains locked - won't unlock
Depress and hold the heated dry button until the light goes out. This may take more than the suggested 4 seconds (Sears suggestion).
6helpful
2answers
Cannot turn on cooktop.
I have a Kenmore Elite Induction Cooktop and we had some milk boil over and now the cooktop is locked. How do you unlock it?
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
