Question about Health & Beauty
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
Posted on May 14, 2010
SOURCE: My blood pressure monitor is
Contact the HoMedic's Consumer Relations Dept @ 800-466-3342 Mon - Fri, 8:30am - 5:00pm ET, they can help you.
Keep in mind, that improper placement of the wrist cuff can cause higher or lower readings, than what they truly are. Also, not keeping your arm at heart level can cause an inaccurate reading.
Posted on Mar 01, 2011
Sep 20, 2014 | Health & Beauty
Feb 18, 2014 | One Touch A & D One-touch Blood Pressure...
Jul 25, 2013 | Oregon Scientific Wrist Blood Pressure...
Apr 04, 2011 | Walgreens Blood Pressure And Pulse Monitor
Mar 22, 2011 | Homedics Automatic Arm Blood Pressure...
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Feb 01, 2009 | Homedics Deluxe Automatic Arm Blood...
Feb 20, 2021 | The Health & Beauty
