SOURCE: Please Help.I have Dell vostro 1700.Need master password
Reset Admin/User password for Windows XP (SP1 and SP2), 2000, NT, Server and Vista
DL link:
http://www.4shared.com/file/44042646/f7f4da54/KesatriaBajaHitampart1.html?dirPwdVerified=2818960c
http://www.4shared.com/file/44046615/9ce8e8fc/KesatriaBajaHitampart2.html?dirPwdVerified=2818960c
For Dell Only:
This removes bios password from any Dell machine. unrar it and Burn the Boot CD, and then Boot to it
http://www.4shared.com/file/82179383/4262ad3d/DELL_Bios_Pass_Killer_2008_By_Virility.html
pw: www.dl4all.com
SOURCE: Dell vostro 1500 has BIOS PASSWORD
It sounds like you are prompted to enter bios password. Call dell tech support and they will generate unlosk code for you.
SOURCE: please help me bios password, which is admin system dell latitude D620
remove the laptop and, bios battery wait 10 minutes then reconnect the bios battery and repower with the power supply
SOURCE: I installed Dell Vostro 1000
Yep I did the same. Finally recovered using the link shown below.
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button
WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
Good luck Dean/Steve
