Question about Maytag Dishwashers
First step is similar to a computer. Reboot. Turn off your dishwasher at the breaker box. Hopefully your electrician designated a separate breaker for your dishwasher, otherwise whatever else is on that breaker will be off. Shut the breaker off; wait 10-15 minutes; turn breaker back on. This will resolve many issues and is the first step to try.
Posted on Jun 08, 2019
SOURCE: maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
SOURCE: Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Posted on Mar 03, 2010
SOURCE: my Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Apr 18, 2012
