Question about Dell Computers & Internet
I transfered fifa 14 on my Dell latitude 3150 but the e0001 code pops up on trying to launch it what do I do
Posted by NANA ELISABETH on
Robert Melton Sr.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Uninstall it and re-install it. That should work fine.
Posted on Jun 08, 2019
5 Related Answers
Anonymous
SOURCE: HI I DOWNLOADED FIFA 2011
I have the same problem, E0001 occurs when I want to start maybe system requierments are too high for my pc..... ??
Posted on Sep 16, 2010
Anonymous
SOURCE: When i open fifa 11
while starting fifa e0001 comes
Posted on Oct 08, 2010
Anonymous
SOURCE: What does E0001 mean when
Error Message E0001 = This game requires a shader model 3 (or better) card. Your Card doesn't support pixel shader v3.0 probably.. this is usually the case with unsupported graphics cards.. bad luck dude.
Posted on Oct 20, 2010
yaoyang
  • 2340 Answers
SOURCE: I INSTALLED FIFA 11....BUT WHEN
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps.
Posted on Nov 22, 2010
richard_agyi
Richard Ded
SOURCE: e0001 comes in fifa 11
I want to play fifa12 but i get E0001
Posted on Oct 09, 2011
When i start my fifa 12 i get E0001 error
Do you also get any 'beeps'? If so how many and what pattern (if any)?
Dec 27, 2013 | Microsoft Windows 7 Home Premium 32bit 1...
When i open fifa13 on my pc E0001 displays
Have a read through this, hope you find the solution there:
http://answers.ea.com/t5/FIFA-14/SOLUTION-Crashes-Not-launching-and-the-E0001-error-Fifa-14-1/td-p/1502133
Nov 11, 2013 | Computers & Internet
Error code e0001 for fifa 12
how tou remove the error e0001 ?
Nov 17, 2011 | Computers & Internet
When i try to play FIFA 2011 it keeps showing e0001
FIFA 2011 it keeps showing e0001???
Your Graphic card does not support the FIFA 2011 game.
Get a better graphic card which support at least "Shader Model 3". Most of the intergrated ie onboard graphic cards do not support the game.
Hope it helps.
Feb 23, 2011 | Computers & Internet
I cant start my fifa 2011, shows me E001
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Jan 25, 2011 | Computers & Internet
My fifa 11 no working e001 problem
Jan 23, 2011 | Cisco IOS IP/FW/IDS 12.2(11)T...
I installed FIFA 11 on my PC and when I run it it comes up with a box say 'E001'.
Jan 11, 2011 | Video Game Consoles & Games
When i run fifa 11 after opening fifa config it shows "e0001 error" please help me !
FYI
Hope it helps
Dec 21, 2010 | Computers & Internet
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
Dec 10, 2010 | Computers & Internet
I installed Fifa 11 When i start it, a dialog box appears stating "E0001" whats the probem and how to solve it?
This is due to your graphic card not supporting "Layer 3 mode or better". You need a better graphic say with "layer 4 mode" support to play the game.
FYI
ATI Radeon HD3200, HD4350 and
Hope it helps.
Oct 14, 2010 | Computers & Internet
Open Questions:
Computers & Internet Logo
62 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
