H2 error 11tr duct table Ac - Office Equipment & Supplies
Posted by Jot singh on
My 2005 H2 blows cold out of the driver side ducts and very hot out of the passenger side. Is there a reset for the blend doors?
YOU CAN TRY DISCONNECTING THE BATTERY, IF THAT DOESN'T WORK U MAY HAVE A BLEND DOOR THAT IS DEFECTIVE ON THE PASSENGER SIDE.
Jul 23, 2009 | 2005 Hummer H2
Bosch tankless water heater error h2
H2 wasnt an error code on those machines... could you check the display and ask again?
Feb 11, 2014 | Bosch & Tankless LP Hot Water Heater
'01 Honda Accord, EX-L, V6, Code P0401 comes up at Auto Zone Is this a DIY job? Fairly handy
code P0401 is an EGR code.
which is insufficient EGR (exhaust gas recirculation) flow.it is quite common for people to just replace the EGR valve.
You can try doing it your self.:----
To troubleshoot these issue and solve it yourself.I suggest you to go through few help links related to
OBD code P0401:-----
Click the link below:-----
1997 Chrysler Sebring: OBD Error Code P0401?
http://howtobyme.blogspot.in/2012/06/1997-chrysler-sebring-obd-error-code.html
2004 Hummer H2: OBD Code P0141?
http://whoisbyme.blogspot.in/2012/06/2004-hummer-h2-obd-code-p0141.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
These will help.
Thanks.
Nov 28, 2012 | Honda Accord Cars & Trucks
LP HP CF Blue star
11TR Blue star Ductebal AC LP HP CF porbalem
Jun 12, 2012 | Heating & Cooling
Display error H2
Gwnerally in sharp you cancel H2 doing a reset through code 14. did you do it yet?
Dec 03, 2011 | Office Equipment & Supplies
My H2 AC light just flashes and then goes out.
If the AC light does not stay on after you push the button and the air does not get cold coming out of the vents the system has a leak and has been evacuated. Once the pressure falls below a certain level the pressure sensor in the AC system tells the AC clutch to dissengage and the light on the dash will also go out to alert you that the AC system is not functioning correctly. The reason it flashes when you push it initially is that the system is trying reading the system pressure and finds none.
<br>Sgt Lumley
Apr 15, 2011 | 2004 Hummer H2
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
Feb 10, 2011 | Sharp AR-M237 Digital Copier
Aircon not blowing through dash vents
If it blows thru other vents, your air ducts may have come loose. If you don't get any cool air, your coolant is low (it evaporates during the time and below some point it will not circulate anymore). Also the aircon blower can be faulty.
Dec 03, 2009 | 2005 Hummer H2
Will not power on from ac or batteries
I happen to know that for this certain camera it uses a battery which if it runs low enough on EN it will actually burn through the S.disc of the E!Reader in the batteries supplementary storage facility. In simple terms, a new battery is required, unless of course you want to spend $600 repairing the battery through an expert which now-a-days is almost impossible to find.
Oct 11, 2009 | Sony Cyber-shot DSC-H2 Digital Camera ...
27 people viewed this question
Ekse
Marvin
Marvin
