Car Audio & Video Logo
William Barker Posted on Jun 08, 2019
I need colour code diagram for Sony cdx-gt07
I am making my on harness
Mechele Lea Bolton
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 09, 2019
Mechele Lea Bolton
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
240
Points
Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
5 Related Answers
Anonymous
  • 8197 Answers
  • Posted on Jan 17, 2009
SOURCE: Where can I get a wiring diagram for my Sony Explod CDX CA650 ??
http://safemanuals.com/annexe_Installation%20Guide_SONY_CDX-CA650-_E.htm
Good Luck
Anonymous
  • 1126 Answers
  • Posted on Nov 06, 2009
SOURCE: I need to buy a replacement wiring harness for my
Here is a link to Sony for parts available for your CDX-GT07. Though I don't see a harness as an option here.
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=CDXGT07
Sony head units normally have either a 9 pin or a 16 pin harness. Here are both links respectfully.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
Anonymous
  • 1126 Answers
  • Posted on Dec 03, 2009
SOURCE: need to know the speaker wiring code from the back
This is a link to Sony for your CDX-GT07 wiring color codes.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C217600&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=151784013&stateId=0 0 151782618
Testimonial: "i want to thank you all for your help. you gave what the sony web site would not help me with. "
Anonymous
  • 1126 Answers
  • Posted on Jan 09, 2010
SOURCE: Need A wiring harness diagram for sony CDX-GT300
Sony head units use either a 9 pin connector, link below:
Or a 16 pin connector, link below:
And here is a kink to your installation guide.
http://www.docs.sony.com/release/CDXGT300_Installation_Guide.pdf
And your Operating Instructions.
http://www.docs.sony.com/release/CDXGT300.pdf
Anonymous
  • 11 Answers
  • Posted on Mar 14, 2010
SOURCE: need a wiring diagram for a sony cdx-gt08 it is
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Sony cdx m600 wiring diagram
See the wiring diagram on the final page of this installation manual: http://www.docs.sony.com/release/CDXM600install.pdf
3helpful
6helpful
2answers
I need the wiring diagram for a Sony CDx 4000x
Your wire diagram should be this in a harness!
CLICK HERE FOR DIAGRAM
Please do be considerate and leave some feedback and rating before you go, Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2helpful
I was given a cdx-gt07 sony fm/am compact disc player and i need a wiring diagram to install the radio. where would i get one. joeturtle
had a search around and found a manual for you to download:
www.retrevo.com/support/Sony-CDX-GT07-Car-Receivers-manual/id/16768bh031/t/2/
1helpful
I want to install a Sony CDX-SW200 cd player in my car and need to find a wiring diagram. Where can I find one?
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
1helpful
Need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
Need wirin diagram for sony cdx-gt310
http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Here is the schematic you need.
I would advise buying the aftermarket wiring harness female/male so you can just plug it in.
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
