Question about AGPtek Computers & Internet
AGPTEK Metal M6B 8Gb How to add music files to the player
I only have USB 2.0, but I can't get Windows to recognize it as a device.
Posted by Michael Moulds on
  • Anonymous Oct 29, 2021
    it is 2018 oldest model
    the player has 8GB deep inside flash memory and 128GB max , micro SD card,
    both can be used,
    if the player sat for 3 years, not used or charged the battery is not useless inside, (gross neglect)
    to add fails drag and drop them,
    same as you can do cell phones via USB2 up.
    there are no login rules like a cell.
    it just works.
    internet connect first time used (per PC)
Larry Ng
  • AGPtek Master
  • 6,548 Answers
They moved their web site
AGPTEK makes vast things from china to here.
no oS told just windows, w10 assumed.
m6b manual is here, at makers site still
Cassette to MP3 Converter, USB Cassette Player Recorder to MP3 Convertor, Portable Audio Tape Player USB Cassette Capture for Mac PC Laptop
http://www.agptek.com/index.php/product/8gb-metal-mp3-player-with-touch-button-and-loud-speakeragptek-m6b-lossless-music-player-with-1-8in-tft-screen-headphones-support-up-to-128gb-black/
I found it searching on THEIR web site. (google AGPTEK home) bingo land there
and searched there.
1: must be charged first, it has batteries.
windows must be internet connected for PnP plug and play to work for drivers, Just like doing same thing to a cell phone the USB2 is not and issue but is a super old PC, not told by you, is this virus magnet XP?
the manual is here
https://images.agptek.us/Download/User_Manual/M6,M16_User_Manual(Detailed_version_in__English_German_Italian_Spanish_Japanese).pdf
2: it must be USB port charged best is 2amp rated (1am min) USB to wall AC charge power adaptor.
2a: page 4 in them manual shows 2 hours to charge.
3:: page 13 shows.
Windows98/ME/2000/XP/7/Vista/10/
Linux6.2&10.10/Macos10.3&10.5&10.6
so it does work on all windows. if you are internet connected only first time used,called PnP
4: in windows device manager the driver for this M6 must show up there, if shows errors click(r) update driver.
5: ok now the driver is loaded.
6: now in THIS PS(my computer) start button , use windows LOCAL explorer to find M6 and copy files to the m6
page 4 in the manual is horrible, for sure.
AGPTEK-M6/M16 (must be seen in device manager and in my computer, (manual shows names)
if yes copy Mp3 files to there, and it is ready to play them.
the battery must be charged and good
and internet connected first time to get any pc to connect, and use PnP driver from MS.
there is no CD
and only PnP works for drivers. plug and play.
Posted on Jun 07, 2019
    battery must be charged, if very old the old battery is no good replace it.
    must be internet connected the PC, first time used, just like doing any cellphone, same comms USB
5 Related Answers
Anonymous
SOURCE: Windows Doesn't See Music
You probably switched it to MSC mode. If you go to Settings->USB and select Auto-Detect it switches it MTP (media transfer protocol?). The player understands both transfers, but they're invisible to one another.
Posted on Feb 21, 2007
Anonymous
  • 4 Answers
SOURCE: Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Posted on Jul 15, 2008
Anonymous
SOURCE: computer does not recognize usb device
Go into the settings menu, from there, go into usb mode...there are two settings: mtp & msc... my player was using mtp and wasn't being recognized, so I switched it to msc, and the computer recognized it.
Posted on Oct 24, 2008
Anonymous
SOURCE: I HAVE AN EMERSON MP3
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
Posted on Apr 01, 2009
Anonymous
SOURCE: Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Posted on Jul 25, 2009
How do I download music onto a Bush KW-MPO3
I believe that the model is the Bush KW-MP03; it's an 8GB music player with LCD. To add music to the MP3 player, connect it to your computer with the micro-USB charging cable (or a replacement) that came with it. The computer must be on but the player can be on or off. Note: the KW-MP03 drivers are compatible with Windows or Linux; drivers for Macintosh OS versions are not available. The MP3 player will act like a USB flash drive. Locate it in File Explorer (Windows) or mount it (Linux). Open a second File Explorer window (Win+E) and go to the folder with the music files you want to add. Just drag and drop files from one folder to the other. Alternatively, copy the files by typing the commands in a terminal or command prompt window.
Bush has the manual here: https://www.argos-support.co.uk/instruction-manual/6165712-bush-8gb-mp3-player-with-lcd-black.pdf .
I hope this helps.
How to add songs for sony digital music player NW-S703F
When you connect the MP3 player to yourcomputer with the supplied USB cable then computer detects the player as anexternal storage device or a Removable disk, you can then view the folder onyour MP3 player. Open the music folder and create a new folder on the playerexactly the same way you create a folder on your computer's hard drive. Toorganise your music, make a folder name with the name of the music album andplace the album's MP3 files in this folder, then copy the mp3 files from thecomputer into this folder.
You will then be able to select the music you want to play by the music albumfolder.To delete a filefrom your MP3 player, connect the supplied USB cable to your player and thenplug it into the USB port of your computer.
The computer will detect your player then click on this device to view thefiles, you can then click on the music file to highlight the file and thenpress the Del key to delete the file off your MP3 player. MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
How to put msic on it
Install the Windows driver included in the product package before connecting your Sylvania MP3 player. Insert the included driver CD into your CD-ROM drive and run the setup file if it does not load automatically. This driver makes sure your computer can recognize and operate the Sylvania MP3 player.
  • 2 Insert one end of the USB cable into the USB port on the Sylvania MP3 player.
  • 3 Insert the other end of the same USB cable into the USB port on the computer.
  • 4 Wait for the computer to recognize the Sylvania MP3 player as a connected device. Open your file manager or browser to locate the Sylvania MP3 player as a drive or connected device if your computer does not prompt you automatically.
  • 5 Open the file folder containing the MP3 or WMA digital music files you wish to download to your Sylvania MP3 player.
  • 6 Drag and drop the file or folder icons of your desired digital music onto the Sylvania MP3 player device icon. Drag and drop the digital music into open folders within the Sylvania MP3 player device icon as well.
  • 1helpful
    2answers
    USB Port Not Recognized
    Here Two Reason for USB Port Not Recognized:
    1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
    2. If again these problem shows. go to,
    My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
    2helpful
    2answers
    No pc recognizes the V-touch 8gb mp3 player by Visual Land
    Windows xp, Vista, and Windows7 should already have a driver included for the v-touch. It's possible that if your computer has a compact flash card reader, that it maybe preventing the v-touch driver from being correctly installed. Try using the "Safely remove Hardware" to temporarily remove your cf card reader. Then try plugging in your v-touch. It should now correctly install the driver and the v-touch will show up as a new drive. In Windows Device Manager under "Disk Drives" you should see 2 new devices - "Company PNP Platform OPN USB Device" and "Company PNP Platform SDC USB Device
    Help me
    Make sure your device is under MTP mode...to do that go under the menu settings, usb and device mode and change it to MTP
    Assuming that you have windows media player 10.
    1. Creating a selection in Windows Media Player
    Launch Windows Media Player 10. Click on the Library tab then Add to Library > Add folder and select a folder (e.g. compilation of favourite songs, converted CD, folder of downloaded songs, etc.) from your hard drive (See Image 1). Click OK to confirm your selection. Your folder data will appear in the main window. Repeat the procedure for your other albums.
    You can also do this by clicking File > Add to library > Add folder.
    When your folders are ready, click-hold to select all your songs and then drag them to the window on the left, as indicated. Select the entire list again and click Now Playing List and select Synch List (See Image 2).
    2. Transferring your selection to your MP3 player
    Click on the Synchronize tab. Connect your MP3 player to your computer, your player will be automatically recognized by the computer and synchronization (that is file transfer) will begin immediately.
    3. Transferring your MP3s to flash memory
    Insert the memory card from your MP3 player or MP3 phone into your computer's card reader and open My Computer. Windows XP will automatically recognize your memory card and its icon should appear next to the other icons.
    Click on its icon to open your memory card.
    Select the MP3 file to transfer. If you want to transfer several files at once, control-click each individual file. In the File Manager window, click Copy File and select the destination folder.
    Check this site for more clarification...I hope this helps..
    http://technology.sympatico.msn.ca/How+to+transfer+music+to+an+MP3+player+using+Windows+Media+Player+10/How-To/PortableDevices/ContentPosting.aspx?isfa=1&newsitemid=a5dc6462-1612-44e5-a75b-e83cbbd7f373&feedname=HOWTO_PORTABLES_EN&show=False&number=0&showbyline=False&subtitle=&detect=&abc=abc&date=False
    I hope this helps
    Please rate accordingly
    Thank You
    Computerrep
    1helpful
    8answers
    Sandisk Sansa View 8GB = would not connect
    I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
    1helpful
    3answers
    Deleting files from Sansa e250
    The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
    1helpful
    2answers
    GPX MW6815DT trouble
    For those that still use this mp3 player here are some things you need to know.
    the gpx mw6815dt can operate as a media player or a usb storage device.
    you need to change which state it is in via the System option.
    Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
    Note: DRM only works when the gpx is in Media mode.
    If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
    Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
    Computers & Internet Logo
    Top AGPtek Computers & Internet Experts
    Ekse
    Are you an AGPtek Computer and Internet Expert? Answer questions, earn points and help others
