Locks & Locksmithing Logo
Laurie Gerke Posted on Jun 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ezset electronic keypad deadbolt: how do you turn off Auto Lock? I have followed directions in manual and it keeps auto locking on me.
Chris Walker
Level 3:
Top Expert:
  • Locks & Lock... Master 1,573 Answers
  • Posted on Aug 01, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245635
Points
21965
5 Related Answers
Ekse
  • 13435 Answers
  • Posted on Apr 27, 2008
SOURCE: as you asked
ok, so all the locks are off on the phone.
The imei code is valid no one has changed it.
Its possible that the phone has been reported stolen?
Anonymous
  • Posted on Sep 30, 2008
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Jul 22, 2009
SOURCE: deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Anonymous
  • 72 Answers
  • Posted on Aug 29, 2010
SOURCE: I want to Disable Auto Keypad Lock while calling
There's actually no way to do that. The phone automatically locks once a call comes in. I am also a user of this phone and tried to search for this answer myself, but, unfortunately, there really is no way to turn it off.
Anonymous
  • 963 Answers
  • Posted on Apr 18, 2011
SOURCE: Kwikset keypad deadbolt will not lock or unlock.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
How do I reset factory settings on facto electronic deadbolt
Indeed, the Facto lock is currently sold as Kwikset's "264 Contemporary Keypad Deadbolt".
However, Coaltowner's link points to the general FAQ page. Here's the page with the PDF user manual (in case anyone else is looking for it):
www.kwikset.com/products/detail/264-contemporary-keypad-deadbolt?variant=264cnt-15
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
3helpful
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
2answers
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Trying to install the keypad and deadbolt. I do not have directions Thanks
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
1helpful
Our powerbolt does not work well in the cold. It appears as if the batteries no matter how fresh, are not strong enough to turn the bolt. I thought I had seen a new model where the keypad simply unlocked...
Batteries, when they are cold, do not give off the same amount of power. You can test this by putting them in a freezer for a few hours and then trying them in a battery operated device. They cold does not hurt them, and they will work fine once they warm up. Depending on how cold the batteries get for your deadbolt this could be the problem. Also if the deadbolt is rubbing at all against the lock plate it could put unnecessary pressure on the motor. Schlage does make a deadbolt system that uses a keypad and a manual turn. The Camelot or Plymouth models.
3helpful
How do I reset the code? I just moved into a house that has one but no instruction manual.
On the inside under the back plate you will find a button on the bottom left. Press button once enter you code 4-8 digits. Then press lock. Re-enter the code. If it unlocks you code is entered. This unite can keep two codes. To set the second code hit the back program button twice and follow the above directions. Also not the key lock is a Smartkey sysyem so you can change the key also.
3helpful
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
