Question about Generac Electrical Supplies
25K Generac Generator from natural gas to propane
I have a natural gas unit that I want to run on propane. It's a model QT02516 25KW from 2008
Posted by James Busbee on
Steve Pack
  • Generac Master
  • 4,331 Answers
You will need to change jets. You may find that no one will seel it to as you are licensed.
Posted on Jun 07, 2019
5 Related Answers
bigg t
anthony james
  • 640 Answers
SOURCE: converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Posted on Dec 12, 2007
jrichson
SOURCE: Convert natural gas range to propane
I want
Posted on Jun 09, 2008
Anonymous
  • 30 Answers
SOURCE: my standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Posted on Jul 01, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: The generator starts up runs for about 15 seconds and shuts down.
Check the oil pressure switch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 21, 2009
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: Recently a Generac 17kw natural gas generator was
There will be a normal odor as the engine cranks until enough gas is in the intake for starting. Gas generators do not have an ignition 'on-off' switch, they use a fuel solenoid to turn on and off the gas to start and kill the engine. If you are uneasy, your local gas company should be able to check engine compartment for leaks. Here in my home town, the gas company will inspect any equipment for gas leaks and/or carbon monoxide levels free of charge.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Dec 24, 2009
Testimonial: "Tks for the feedback on this problem, it is very informative. The faint gas odor persists when idle. Would this suggest a defective solenoid."
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
I have a toy hauler with a generac generator propane that wont start getting gas and spark but wont start model 04164-0
Check the comprssion, if you are sure you have a spark and gas. Is the fuel been delivered to the cylinders? Check the fuel solenoid for power, if power is present the demand gas regulator maybe gummed up. LP companies put a waxy lubricant in the gas and over time this can build up and harden in regulators. Also during crank observe the throttle is it going open as it should? if not suspect a control issue
Oct 17, 2013 | Generac 40 Kw Natural Gas/propane...
I have a Generac 60kw generator. When it runs under load the generator surges, causing the lights to go up and down. The only way to stop this is if I reach into the generator and grab what I think is the...
You did not specify fuel. If running natural gas or propane, check the diameter of your feed line. You need at least 1/2 to 3/4 pipe diameter on the NG or propane. At 60KW I would guess at least 3/4 maybe larger for NG.
Sep 16, 2013 | Generac Power Systems Commercial Series...
Need adjustment procedure for a Generac Centurion generator, carb and regulator under full load
Before you adjust anything, suggest you verify gas line for proper pressure and importantly volume. Pressure for gas should be 5 to 7 inches and propane 11 to 14 inches W.C. Also make sure the line to the generator is sized properly and the gas meter is a high volume unit (if NG). 90% we find the problem with generator sunder load that otherwise are fine are fuel related. Good luck.
Sep 19, 2012 | Generac Power Systems Centurion by 16000...
LPG / NG portable generator runs on propane but wont run on natural gas
While propane and natural are similar, some devices require changes to properly operate on the selected fuel.
Information about this should be in the owners manual for the unit.
An off the cuff guess is that the gas pressure from the NG source isn't high enough, or that there is a gas regulatior on the generator that would need to be adjusted for NG.
Oct 26, 2009 | Electrical Supplies
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
159 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
