Where is the water coming from and how do we stop it. It never did this last year.
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
SOURCE: Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
SOURCE: Maytag refrigerator ice maker, pouring water out where ice should
change ice maker or check defrost
SOURCE: light like an exclamation point keeps flashing on the dash
It's a warning to "Check Transaxle". A problem was detected and shifting may be limited. Get it looked at soon.
