SOURCE: Jazzy 1200 power wheelchair is electrically
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Posted on Mar 27, 2009
SOURCE: Somehow I have locked my Jazzy 6 Select Electric
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
Posted on Mar 29, 2010
SOURCE: i need the manual for
It's available to download in adobe reader format from http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Quantum%20Jazzy%201470%20Owner%27s%20Manual.pdf You'll need adobe reader to read it. If you don't have it you can download it free from http://get.adobe.com/uk/reader/
Posted on Aug 17, 2010
SOURCE: I need a schematic for a Electric Mobility
Contact the Rascal Company @ 800-662-4548 They are the manufacturers of that chair they should be able to help
Hope this helps you
Posted on Sep 08, 2010
SOURCE: replaced battery in jazzy 600
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Posted on Oct 29, 2010
Jul 08, 2014 | Select Jazzy Used Electric Wheelchair
Feb 13, 2014 | Select Jazzy Used Electric Wheelchair
Apr 29, 2013 | Pride Mobility Products Used Jazzy...
Jan 04, 2012 | Pride Mobility Products Used Jazzy...
Aug 25, 2011 | Pride Mobility Products Used Jazzy...
May 17, 2010 | Pride Mobility Products Used Jazzy...
May 16, 2010 | Pride Jazzy Select 6 Indoor Power...
Apr 21, 2010 | Pride Mobility Products Used Jazzy...
Apr 28, 2009 | Pride Mobility Products Used Jazzy...
Jan 02, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Feb 20, 2021 | The Health & Beauty
