Question about Refrigerators
I have a Kennmore Elite, bottom freezer refrigerator that the ice-maker stopped working. The freezer is also not freezing at the selected level (around 30 degrees and not 0 degrees).
Posted by Bob Wilgus on
5 Related Answers
Anonymous
  • 363 Answers
SOURCE: ice at the bottom of the freezer
It sounds like the freezer has leaking door seals and air is getting in to the freezer compartment. Your temperatures are set about right. Regards
Posted on Oct 02, 2007
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
Anonymous
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
Anonymous
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
Anonymous
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Samsung refrigerator ice maker
Many icemakers use a bar or a sensor to shut off water when ice levels are at a maximum. Check to see if it's bent, missing, or pushed down below the ice level, tricking it into thinking there's no ice there.
Aug 03, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Have a kenmore elite bottom freezer that is not
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Same problem
i suspect it have a leak the gas level are very low
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
