Question about Radio Communications
The medal punches will not release the paper unless you press the punch button a second time. Do these machines need to be periodically oiled?
We have a SircleBind CB 3000
Posted by Mary Meier on
5 Related Answers
Rick Kasper
  • 2072 Answers
SOURCE: Xerox hole punch -
Its become dull or developed burrs on the shaft, should be replaced.
Posted on Aug 05, 2008
Anonymous
  • 73 Answers
SOURCE: Home Design 3000
The textures going to the sky / grass is a classical issue of a videocard problem
Try to follow these steps
1 - Go to the website of your video card manufacturer (it can be found using any search engine and the manufacturer's name and the card model). Look for downloads, and see if you have the latest version of driver software for your model of video card (you can find your current driver's version at Video Settings->Advanced->Adapter). If there is a newer one for your card and the operating system, you are running, download and install it following the manufacturer's directions.
2 - Click on Start->Run and type in "dxdiag", and click Run. The DirectX diagnostic will run, and tell you what version of DirectX you are currently using. Go out to www.microsoft.com/directx, and see what version is current. If your version is not current, read the install instructions, the system requirements, and the FAQ. It is recommended that you download the latest version and install it.
3 - Try to slowdwn the videpcard accelerations: To slow down accelerations--> click on an empty part of the windows Desktop, click on Settings->Advanced->Troubleshoot. Back the accelerations slider to the left, one level each time and see if the problem dissapears
Posted on Oct 30, 2008
John Dezember
  • 16 Answers
SOURCE: Deleting Blank sides of paper
The KV-S3065C scanner driver has features to help with this:
  • Image enhancement - Hole Removal
  • Blank Page Detection (and removal)
Of course, the software you are using will determine how/if you have access to these features. The Hole Removal is great, but it really looks for perfect round holes. Blank Page detection is also great; it may take a little tweaking, to get the results you are looking for, but once set it save a lot of time.
Make sure you have the latest drivers: http://panasonic.co.jp/pcc/products/en/scanner/downl_e.htm
Posted on Dec 02, 2008
Anonymous
  • 244 Answers
SOURCE: need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Posted on Jan 16, 2009
Tom Keenan
  • 7 Answers
SOURCE: Broken electric 3-hole punch
There are two phillips screws in the bottom. Once they are removed, the top and bottom of the case are held together with clips molded into the case. Take a wide flat screwdriver and place it in the seam and gently pry it apart. Might want to start on the back in case you ****** up the plastic.
Posted on Oct 25, 2009
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Sircle Corp SircleBind CI-1500e Electric Spiral Binding Machine Jam
Hi Karen,
I would strongly suggest you find a local service technician to help you with this problem as the only way to release the pages is to wind over the electric motor by hand. To gain access to the motor the safety panels will have to be removed. The motor should be able to be wound backwards to release the punches from the pages, this will ensure the punches are not damaged.
If you attempt this repair yourself please make sure the machine's power cord is completely unpluged from the wall socket, not just turn off.
Dec 04, 2013 | Sircle Corp SircleBind CI-1500e Electric...
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Im trying to change the unit of measure i go into "design" but "unit of measure isnt highlighted as a usable option unless im in the home screen where it tells me i can not use this option...
Using Quick start is like a napkin sketch or a fast layout. After you click Continue, you go to the project stage. Therefore, after you press the "Continue" button you will be able to Save, Import, Print, Move, enter inside the house or set the precision and units, as well as use all the Punch features
These are the best resources for Punch Software solutions
Punch Software Community Forum
Punchhelpers Website
Learning Punch Software (R): Basic & Advanced Training
Learning Punch Software (R): Importing, Exporting and Printing
Punchhelpers at Facebook
Apr 21, 2011 | Punch Home and Landscape Design Suite for...
My pictures come out blurry even though the lens is clean, focused and in automatic mode.
Make sure the release button is being pressed, not punched. If you are punching the button you will be shaking the camera making the pictures blurry even if they are focused. The shutter speed should be at least 1/60th of a second, so f the room is dark and you are not using flash this will also make a similar problem. Take it to a camera store for diagnosis
Jan 29, 2010 | Canon EOS Rebel G-II 35mm SLR Camera
How do I lubricate a Aurora AS702MX shredder?
two ways, first take a light oil (3 in 1) and scribble a pattern on a piece of paper and pass it through the cutting heads do this a couple of times, this can be done as you shred just put a little oil on papers you are about to shred from time to time.
second, if it is a light duty machine, with plastic parts, then pass some waxed paper through the shredder to clean and lube the heads, this also works for your 3 hole punches.
Apr 12, 2009 | Aurora Global AS702MX Shredder
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
if you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Jan 24, 2009 | Kyocera Mita KM-5035 Printer
Docu color 252 fault code 012-324 ???? Bill
HERE is the manual for your unit.
HERE is the online support page.
THESE are all the available documents for your Copier
Your error code 012-324 is not listed in any documentation.
Is there something it is doing/not doing when this error comes up?
Their customer service will help you with the error code.
Please call 1-890-925-050 and have your 10 digit serial # available.
Thank you for Using FixYa!
Jan 20, 2009 | Xerox DocuColor 12 Color Copier
Radio Communications Logo
127 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
