Question about Rowenta Irons
How do I get the "Auto Off" button to stop flashing on my Rowenta 1700W brand new steam iron? It keeps turning the iron off.
Posted by Barbara Deekle on
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
Anonymous
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
Anonymous
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: my rowenta iron spits out white particles when I
descale and wash through x5 times ...
Posted on Feb 26, 2011
momzilla1135
SOURCE: rowenta d1700 red flashes and iron shuts off
I am on my 3rd or 4th Rowenta. I recently bought the Rowenta Effective, Model DX 1700. Once again, I am having the same problem as before, it shuts off after about 30 seconds. From what I am reading, many people are having the same problem. I'm going to have to guess, this is a product defect. Do I contact the company for a refund????
Posted on Jun 04, 2011
My Rowenta steamer is brand new never used before. I added the water it worked for 5 minutes then stopped and now it won't steam at all
Hello, Nadya -
Check the warranty information which came with your Rowenta steamer (probably in the owner's manual / instructions. Find out what you need to do to return the steamer for a working replacement.
Best wishes.
Mar 07, 2018 | Rowenta Irons
My new rowenta steam iron is flashing the on button and no steam is coming out of the iron?
It the heat setting turned up? If yes, If its still under warranty, my advice is that you take it back to the seller and ask them to have it checked out.
Oct 04, 2017 | Rowenta Irons
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Jul 29, 2014 | Rowenta DW-8090 Pro Master SEWERS Iron...
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
My Steam Iron Rowenta dx1700 leaks on my clothes and turns itself off while I am ironong. I am ready to chuck it.
My brand new DX1700 iron leaks. Why is it leaking. I had a Rowenta Professional for 17 years and it never leaked. What do I need to do.
Jan 12, 2011 | Rowenta Perfect Iron
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Rowenta model 1700W. Water leaks out front of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
Irons Logo
201 people viewed this question
Top Rowenta Irons Experts
Colin Stickland
Colin Stickland
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
