Question about Hayward Pool & Spa
Hayward H100 nat gas heater stopped burning. Ignites, runs a few seconds, shuts down, it does this 3 times and quits, fan continues to run. Likely cause? Ran fine for 2 hrs.
Posted by Chris on
Simon Fish
    Problem Solver:
  • 14 Answers
Poor water flow or dodgy sensor probe
Posted on Jun 18, 2019
5 Related Answers
Anonymous
  • 54 Answers
SOURCE: the airconditioning fan runs for a few seconds then quits. The rear operates fine.
Sounds like your blower motor has quit if it is inop on all levels. If high speed works and the other speeds do not, then its probally the rheastat or resistor pack
Posted on May 05, 2009
Heath Moyer
  • 767 Answers
SOURCE: goodman 075-3 fan runs but no voltage going to igniter
One thing you can checkmis the continuity through the ignitor itself if you have continutity through that there is also some safeties it has to go through but the board is where the voltage is supplied for the ignitor. I would check the high limit and the roll out before condeming the board.
Posted on Dec 20, 2009
Anonymous
  • 15 Answers
SOURCE: My hayward h400ed2 heater starts for 2-3 seconds
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Posted on Aug 22, 2010
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: hayward pool heater h series
It could be that your gas connection has a blockage that is preventing adequate fuel for from getting to the heater. If that is not the case, try consulting your owners manual for these pool heaters. There is an online copy at the link below.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
rickbrashear
Ricky brashear
  • 176 Answers
SOURCE: igniter goes on blower runs
there should be a flame detector sensor. it is in the flame. this will need to be cleaned with a wire brush or scrapped with something to get the carbon build up off of it.
you will see something that in in the flame area that is kind of charred and black with a wire coming out of it.
this is designed to tell the unit that there is a flame present and if that flame is not there after serveral attempts it will shut it down. because it there was no flame there you would get gas fumes pumped into you house.
you could change it out or usually you can just clean it and it will work fine.
hope this helps
rick
Posted on Jul 15, 2011
I have a hayward SR333Lp that ignites for 5 seconds and then displays service heater. No leds on back of board to indicate cause
Today's gas appliances are designed to shut off when combustion problem is detected.
For example if burner parts are dirty of clogged, the gas valve continues releasing gas, but not all the gas is burned.
This caused potential explosion risk, with unburned gas in the combustion chamber and flueway.
Call service tech to clean combustion parts, check pilot or igniter alignment, check gas control valve, and gas pressure, and bleed air out of gas line if needed.
Search internet for product manual. Product number appears on label, and then add .pdf to search parameter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 03, 2012 | Sta Rite Sta-Rite Max-E-Therm High...
Model #GMPN100-4 Goodman furnace. Vent fan
The sequence of events for furnace operation is -
Fan purge for 30-45 seconds. During this time, a pressure switch is actuated by the running of the purge fan, proving the control board the purge fan is running.
After purge and purge prove, the hot surface ignition and or spark begins. After a few second delay, the gas valve will open. The control board then monitors for flame prove through another sensor located near the burners. If there is no flame within 3-5 seconds, the gas valve closes. It will repeat this process, usually 3 times, before it shuts the system down, which requires a power down of the system to reset.
I have seen trash get into the hose between the purge blower and the purge switch. But you could be having other problems.
Dec 17, 2009 | Goodman Heating & Cooling
Fan on, sparks 3 times, won't run
Shut off the gas to the heater and pull the ignitor out. Turn everything on and push the button in the door opening to get the heater to turn on. Look at the ignitor and see if there is spark across the probes when you hear the clicking. If not, replace the ignitor.
If there is, put the ignitor back in the heater and then look at the valve. The two wires that bring the 115V to the valve need to be pulled and then checked with a meter. Start up the heater again and look for the 115VAC when the ignitor starts sparking. If you see it, replace the valve. If not, replace the control board.
Jul 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Pool & Spa Logo
151 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
