with the original working remote go into the customer menu and it can be switched off---if you do not have the working remote there is usually no other way to do thatwith the original working remote go into the customer menu and it can be switched off---if you do not have the working remote there is usually no other way to do that
You can't post conmments that contain an email address.
hi, in your tv the closed caption option is in on position. make it off o run out the black square. to make the closed caption (cc) off. do the following. 1. press the menu button 2. select setup 3 go to closed caption (cc) 4. select closed caption mute (cc mute) ok
The above link is for the CT-2610 and I can only hope the 2620 is the same. This will open a PDF file. Read this and it should show you how to turn on your CC.
Your closed caption is turned on. Go into the menu and set captions to off or look for captions button on remote. Sometimes identified as cc. Press it until "captions off "appears on screen. That should do it. Good luck.
What you see is called a Text box and it is part of the CC or
closed-caption feature......go thru the menu pages until you
find how to activate / de-activate closed-caption and you will
get the text box off...........................................T.
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption)
Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button.
Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible).
Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
