Question about Dell Computers & Internet
How to connect ASUS chrome box 3 to a dell monitor model u2412mb
Posted by ALBERT NASH on
Larry Ng
  • Dell Master
  • 5,978 Answers
No exact PC stated, but Box 3 and u2412.
just looking tells you your choices. and what is best for you of all choices.
but the box3 has only one jack , called HDMI and you use an HDMI cable to the monitor but wait.
let me guess it has no HDMI port that it>?
im googling 2 times reading both spec pages, easy no?
and shows
DVI-D, DisplayPort, USB 2.0 downstream, USB 2.0 upstream, VGA, audio line-out
so you have 3 choices, there, DVI/ DP and VGA (relic)
so you buy a HDMI to DP converter and it works.
any store selling TVs has this. every one ive ever seen.
and adaptor or the adaptor cable hdmi to DP
there are other adaptor's you many not like
hdmi to DVI-D.
Posted on Jun 07, 2019
1 Related Answer
virtual_a
virtual_a
  • 531 Answers
SOURCE: When I connect my ASUS monitor to my Dell laptop
Hi
You do not say if your laptop screen is working or not or why you want to use an external monitor.
Assuming the laptop has no fault and boots properly, to send the laptop image to an external monitor, once you have booted into Windows, press and hold the Fn (function) key bottom left of your keyboard, near the Windows Logo key, then simultaneouly press the Function key (above the numbers) with the image of 2 monitors, 1 dark, 1 bright (often the F4, F5 or F6 key).
If the laptop's screen is faulty and the above procedure does not work, there may be damage to the graphics card which will probably require specialist repair.
I hope this helps.
Posted on Aug 27, 2011
Add second monitor to Dell All in One
I'm not sure as to which OS you're using, but for Windows 7, follow these instructions...
1) Open Control Pannel
2) In the search bar in the upper right hand corner type "Connect to a projector" (Without the quotations)
3) Select the option Connect to a projector
4) A selection box will appear. Select the option that you want.
picture diagram is included below. :-)
Apr 08, 2014 | Dell, Inc Dell XPS One 27 All-in-One...
Start directly on external monitor
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
May 10, 2013 | Dell Inspiron 1721 Notebook
How do I use the function keys on my Eee PC to view picture through my video projector?
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
Apr 13, 2013 | ASUS Eee Computers & Internet
Can I hook up my vh242h monitor to satelite box and if so what connections do I need
First, look on the back of your satellite box and look for one of the first 3 connectors on this site:
http://ixbtlabs.com/articles3/video/guide-p5.html
They depict D-Sub, DVI-D, and HDMI ports which are all compatible with your monitor. I would suggest HDMI, but any would work fine. You can get these cables at any electronics store (BestBuy, Walmart, etc.).
If you don't have any of these connectors on your satellite box, you will need to get a converters such as this:
http://www.amazon.com/Wired-Up-Premium-7-62M-Component-Cable/dp/B000QEDE76
If these links don't help, reply with what model satellite box you have and I can provide more specific instructions.
Good Luck!
John Vickers
Sep 18, 2011 | ASUS LCD Monitor
Need to know if this monitor is hdcp compatible. Can it support hdcp?
here is the List of compatible monitors with their brand names :
Sony
Sony MFM-HT205
Viewsonic
Viewsonic VP2330wb
Viewsonic VP231WB
Viewsonic N3250W
Dell
Dell 2007WFP
Dell 2407WFP
Dell 2707WFP
Dell 3007WFP
Dell E228WFP
Dell E207WFP
Acer
Acer Al2423W
Asus
Asus MW221U
Asus MW201U
Gateway
Gateway FPD1975W
Gateway FPD2185W
Gateway FPD2485W
Gateway FPD2275W
HP
HP LP3065
HP f2105
Samsung
Samsung 205BW
Samsung 214T
Samsung 215TW
Samsung Syncmaster 225BW
Samsung 242MP
Samsung 244T(US version)
Samsung SyncMaster 244T
Samsung 320P-Black
Samsung 930MP
Samsung 940MW
Samsung 940BW
Samsung Syncmaster 931BW
Samsung syncmaster 226BW
BenQ
BenQ FP241W
BenQ FP241WZ (Includes 1:1 pixel mapping)
BenQ FP241VW (Includes 1:1 pixel mapping)
BenQ FP222WH (Unconfirmed)
BenQ FP94VW (Unconfirmed)
LG
LG L245WP
LG L226WTX
NEC
NEC Multisync 20WMGX2
If you can tell your monitor manufacturers name and model no i can let you know about it. Anyhow the above information will help you.
Mar 11, 2010 | Polyview MNTR |17'LCD V17D Monitor
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
Open Questions:
Computers & Internet Logo
16 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
