Question about Furniture
Where can I get a wiring diagram for my electroluk wine cooler model #LFWC18T6LB
Posted by richard on
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
Timothy Snead
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
Anonymous
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
Rich Wright
  • 286 Answers
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Posted on Oct 08, 2009
Anonymous
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Posted on Feb 17, 2010
IWANT TO SEE AND OBTAIN A WIRING DIAGRAM FOR ELECTROLUXtr 1241
I am attaching the basic Electrolux Wine Cooler diagram it is best however, to see the one on the unit itself.
Feb 03, 2016 | Electrolux Refrigerators
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
I need a wiring diagram for a Breezaire WKE 8000 wine chiller/cooler. Does anyone know where I can download one?
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
Mar 16, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
Quite working out of the blue. light works but no cooling it is a Magic chef wine cooler model mcwc30mcg
if its clicking every few min. its the ptc relay.left of compressor is a shield with 1 screw.behind it on top is the relay with 1 wire going to it.wiggle it out to the left .go to repairclinic.com..part#1206838...
Jul 24, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
My ewave made by magic chef model mcwc 30 mcg wine cooler is 5 years old, it just stopped working. Is it worth fixing or spend over $300 to buy a new one?
it could be the ptc relay.to the left of the compressor.if its clicking its the problem.around $27.00 fix at repairclinic.com..part #1206838 the part is behind the plastic cover with 1 screw left of comp.the top part with 1 wire will wiggle off to the left.
Mar 11, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Jan 29, 2010 | Refrigerators
Danby wine cooler repair
May 10, 2008 | Danby DWC283BLS Wine Cooler
Furniture Logo
175 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
