Whirlpool RBS245PDS Electric Single Oven Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you unlock a whirlpool stove if it locks manual
Chris Sorrows
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 136 Answers
  • Posted on Aug 08, 2009
Chris Sorrows
Expert
Level 2:
Cheetah:
Answers
136
Questions
0
Helped
41411
Points
396
I think you mean if it locks automatically not "manual". There should be small print next to one of the buttons that includes the word "lock". Hold this button down until the indicator goes out.
  • Save_money7 Nov 21, 2010
    I turned off power - circuit breaker - turned power back on - pushed in the door plunger switch at the top right - the lock disengaged - told my wife I fixed it for her... lol
    pressed off/cancel on the control panel - then reset the clock.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6483
Points
How to get the controls unlocked on a whirlpool stove
Anonymous
Level 1:
  • Posted on Oct 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6483
Points
How do you unlock a stove
I have a whirlpool stove/oven model 4454079 with a locked control panel. Can anyone please help me unlock the control panel
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Range.
Whirlpool self cleaning oven model number RBS240PDB4
Do you have digital reading on your stove panel?Is it giving you a code reading.
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 • Ovens
Have a whirlpool stove model # wbp88800. There is
F8Board failureReplace control board (also called ERC or clock).
Whirlpool self clean GGP84803 door won't lock when initialized.It is clicking and diplays locked but I can still open door?
If the lock will not engage and keeps locking and unlocking then turn the power off, slide the stove out to obtain access to its back. Remove the 3 screws from back cover and you will see the locking motor and a switch with a lever that rests on the locking rod. This lever has lost its firmness and does not engage the switch to tell the motor it is locked. Simply take a pair of pliers and bend the lever down to put more load on the lever. Now when the rod turns it will fully engage the switch which will tell the motor that the door is locked. Test your setting to make sure you have it adjusted right and then re-install your cover and push your stove back into position and enjoy your day. Takes 10 to 15 minutes and is cheaper than calling a service tech. Remember to turn the power off when working on the back of the stove through testing and such. No need to get hurt.
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
2helpful
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 • Ovens
2answers
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
