What charges the battery on a zero turn
14.x VDC from the voltage regulator/rectifier. The voltage regulator is powered by the alternator stator windings underneath the flywheel (permanent magnets).
I believe schematics are in the operators manual available for free download from Ferris. www.ferrismowers.com
SOURCE: john deere zero turn mower
Check spark plug and ensure choke is set correctly. Choke all the way out to start, then push back in. Make sure gear selector is in neutral and blade not engaged too.
SOURCE: husqvarna yth 2348how to check and see if battery is charging and
there are one to two wires that come from under the fly wheel. thy are attached to our stator (charging sys) the flywheel has a magnet on it. know the wires my or my not go to a voltage regulator than a fuss and to ether the solenoid battery side, or to the battery. the easy way to check is on your battery with a meter. check battery fri st than start your engine to see if the amps come up should be around 12.9 to 14.6 volt. make sure your at full throttle. good luck, let me know.
SOURCE: Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
SOURCE: ford f350 charging system diagram
I bought a Chilton repair manual found it to be best manual for wire and vacuum line diagrams
