Question about Crosley Washing Machines
I have a crosley washing machine model vaw3584gw1 when I pushed the start button to pause it and opened the lid I forgot about it and when i came back it had finished through now it will only make a draining noise I tried to reset it by turning off and lifting lid 6 times it didn't work what do i do
Posted by Amy Martin on
5 Related Answers
gittos73
peter gittos
  • 247 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
reg501
Richard
  • 413 Answers
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 04, 2008
Anonymous
  • 6 Answers
SOURCE: beko WMA 1715s - won't respond
door lock switch could be your problem..
Posted on Aug 30, 2008
Anonymous
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Posted on Jan 11, 2009
Anonymous
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
May tag centennial washing machine model mvwc400xw1 has a button to start,pause,machine...will no longer work..can this be replaced. Runs fine if I can get it started..slamming lid sometimes help.
the machine will do nothing until the door or lid is detected as closed
so your fault is the door detect or ' interlock'
is the issue
not the button buddy
Apr 28, 2015 | Washing Machines
Mw512 beeps and wont start
The lid switch sounds logical. That would certainly halt the cycle. I'm not sure what actuates the lid switch on your particular model but check it as well. Good luck.
Jan 13, 2013 | Fisher and Paykel Washing Machines
I have a whirlpool washing machine, M 31062, WTW4950XW0. I am attempting to use it for the first time and the Sensing Light is coming on when I press START. The Lid locks and there is a noise like the...
I have a Whirlpool model WTW4950XW0. Once i push the start button.
The lid locks, sensing lite on, machine goes through its cycle, than lid unlocks
monents later.What wrong. I was doing laundry and notice the machine making some noise on the spin cycle. I push the pause button and remove some clothes.
thats when the sensing lite keeps blinking.
thanks
Rich
Jan 01, 2011 | Whirlpool Washing Machines
Water will fill into my Crosley front loader CW5000 but will not start washing, rinse, or spin
Sounds like you have a motor issue, listen when you press the start button, if you hear any squealing noises or any of the noises the system usually makes doesn't occur, then you probably have a motor issue, you may need to have your motor replaced
Jan 05, 2010 | Crosley CW5000 Front Load Washer
Is there a reset button for my Whirlpool Cabrio Washer? Every time I start a load of laundry to wash, the washer puts the cycle on pause at least 5 times. I have to hit start, wait for it to beep, hit...
Check the lid switch and its actuator on the lid. The pause you're getting is likely an open lid sensed by the washer control. Also try to push and pull the inner tub up and down a few times - if I remember correctly these washers have a floating basket, which engages the gears when there is enough weight inside. If there is not enough clothes it may not wash correctly (I don't remember exactly, but try it anyway, what do you have to loose? ;) ).
Nov 02, 2009 | Washing Machines
Started the washer and then it stopped and machine
Try pushing the basket to the back so you can reach the lid switch housing - you should be able to re-align it by hand.
If that is impossible, that means the lid switch plastic housing broke loose and needs to be replaced.
I would need a model # so I can help you with instructions.
Aug 18, 2009 | Maytag Washing Machines
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Machine wont start
oohhhh. gwl10 os asearly as my knowledge about these machines go, placing a call to manufacture migh be helpfull . do any indicator lights blink when washer stops??? those are the codes so write down which ones are blink, if i had to guess though id lean toward an ou-of-balance switch failure. on my gwl10 thatslocatedunder console on right side, white bar hanging down measuring time tub hits into it. the switch usally corodes out. hope thats somthin anyway
Mar 01, 2008 | Washing Machines
Washing Machines Logo
Top Crosley Washing Machines Experts
peter gittos
peter gittos
Michael Thomas
Michael Thomas
jdthefixer
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
