Question about JVC Televison & Video
Hi, every time when there’s a power outage my JVC tv won’t switch on for atleast 2-3 days. What could be the problem?
Posted by Solly Kgoete on
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
I need advise who can fix my TV
https://en.wikipedia.org/wiki/Uninterruptible_power_supply
suspect line voltage could be too low. suggest getting it tested to see what voltage is at outlet .May be brownouts or one phase is missing in street power lines. I had this happen a fuse on the power pole in street blew and the voltage was low to my house until power company fixed fuse. How old is the wiring in the house it may need checking if old as well as switchboard by an electrician.
This problem may be a warning sign of future wiring problems in your house !
Nov 11, 2015 | JVC Televison & Video
My JVC mx-g50 component flashes a PROTECT sign everytime I press the power button.Why?
Hi Robert,
Unfortunately, your unit has a built in microprocessor that is very susceptible to electrical interference like power outages and lightning. JVC recommends that you unplug and plug your unit back in like that's going to work. Might be time for a new unit.
Mar 03, 2015 | JVC Audio Players & Recorders
After a power failure / electricity tripping my JVC Lt-39N510 LED TV has no power. The display light does not come on. I switch off the power button on the side, take out the plug. After two days, I plug...
Check and replace its main power regulator board. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 05, 2014 | JVC Televison & Video
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
JVC tV D series will not turn on when I hit power
Hi There,
Did you try turning it on from the actual TV power button?
Mar 22, 2009 | JVC AV-32D305 32" TV
Philips HDTV does not turn on
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
After power outage, TV screen is blank
It sounds funny but, unplug the set for 30 seconds to allow the TV to reset then see if the problem still is there.
Apr 10, 2007 | JVC LT-26WP84 26 in. LCD Television
Televison & Video Logo
29 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
