I have change fusing, Transfer Belt Assembly , imaging unit,
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
SOURCE: sc 481 on my ricoh aficio 1224
The problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
SOURCE: ricoh sc 551
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
If you need to replace thermistors, contact me and I will get you part numbers and instructions.
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
SOURCE: SC 400
Check the connections of the transfer belt unit
can be a false contact.
This code disappears
when shut off and on the copier.
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
