I a an indentation on top of my skull in the middle from left to right. I have a head ache, dizzy, double vision
SOURCE: Double vision with a lot of yellow color
This looks like bad convergance. If only one color is affected it may be one of the convergance IC's. It is best to replace both IC's though. If you change the IC's then check the resistors next to the IC's. Use the exact part numbers. STK392-110 IC's can be upgraded to a STK392-180 for better heat strength. (That is why they blow, too much heat generated. Use a liberal amount of Silicone Heat sink compound.) A shorted IC will usually blow a resistor. If a bad resistor that isn't changed it will look like the new chip is bad. Make sure that you use the same wattage and the exact value (Ohms). Your convergance will not be right with an off value resistor. This info works for about any other brand Projo TV. Cheers, Lee http://www.crazycomputers.com
SOURCE: double vision
convergence fail. try resoldering the 2 convergence ICs in the middle baord located on the large heatsink. this might fix unless the problem has gone it course
SOURCE: Picture is bowed down from
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
SOURCE: HP Photosmart 7550--"double vision"
try giving the selt test copy from the printer only not from the computer.if its proper than the picture setting must be not proper in your pc. and if the test page does not come properly and shows the same problem remove the cartridges and clean it with moist tissue and fit it properlyas it was.
