Question about Samsung Office Equipment & Supplies
I need the software for AGPtek model SC35-5890F Thermal Receipt Printer for my Samsung Chromebook
Posted by Joshua Seguine on
5 Related Answers
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: EPSON THERMAL RECEIPT PRINTER TM-T88IIIP
Use the WIN XP driver. It works OK.
Posted on Aug 29, 2009
jackcity
jackcity
  • 34 Answers
SOURCE: Receipt won't print after paper change (and it IS thermal...)
the possibilities of receipt stop print completely:
1. accidently press the "Receipt Off" button
2. Receipt printer paper jam
Posted on Sep 13, 2009
Anonymous
  • 54 Answers
SOURCE: printing blank receipt every time cash drawer opens
I would try a complete reinstall to make sure the presets of the machine are correct.
Posted on May 27, 2010
Basti
Edgar Allan Pagayona
  • 1447 Answers
SOURCE: I need EPSO Receipt Thermal
Hi!
You can download the software driver for your printer online. Click HERE.
You may need to register first to get a Username and Password
Once you have the Username and Pasword that they will send thru the registered Email.
- Click on Technical Resources below
-Choose Printer Model
-Look under Windows Driver and download the most updated number
-Download and Install
Hope this helps.
Posted on Jan 05, 2011
  • 6120 Answers
SOURCE: i need a user manual for a Epson TM-T88II POS Thermal Receipt Printer M129B
Epson has the manual for the TM-T88II here: http://content.epson.de/fileadmin/content/files/RSD/AnwenderhandPDFs/DE/TM-T88II_user_e.pdf .
I hope this helps.
Posted on Feb 01, 2012
I have a Agptek receipt printer, i replaced a paper roll but the prints are blank
As a rule some printers use thermal paper and if the paper is installed inside out (Backwards) the wrong side is against the print head. If it is an INK system, the ink is dry.
Feb 05, 2018 | The Office Equipment & Supplies
AGPTEK sc9-5870 thermal printer won't print
I got mine to work by changing the port from USB001 to USB002 prints great now, there is problems with installing on windows 8, you have to disable driver verification or the driver won't install.
Good printer don't give up on it.
Feb 07, 2013 | Brainydeal Agptek High-speed 58mm Pos...
My bixolon SRP 350PLUSII is double printing one receipt, please help me how to solve it
There is no option that I know of, on the printer to do this. I suspect this is an option in the pos software that you are using. If you are using windows try doing a test print to the srp350ii from the printers in control panel and see if it prints once. I am pretty sure it will and that will prove that it is something in the software itself.
Oct 25, 2012 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I am using IQ Retail software and have a Bixolon 350 printer. IQ doesn't detect my printer, although, through windows the printer works fine. What should I do?
You might consider updating your printers firmware.This will help increase compatibility of the printer to more and new software.
Visit product support site for updates.
Hope this helps.Thanks!
Oct 09, 2011 | SAMSUNG BIXOLON SRP350 THERMAL RECEIPT...
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Customber recipt check doesnt print logo after i set it up to do so... only prints logo on full professional format on the printer. i checked the printer settings on the software and checked "print logo"...
What version of RPE are you using and what model receipt printer? Version 11.5 with an Epson thermal receipt printer usually requires a special logo designed for that model printer. Not just any jpg or gif graphics file. Epson will create file for you, but it is pricey, around $200 last I checked. I'm not sure if the latest version 12 has a better fix for this or not. And you are right, there is no print preview on receipt printing. Contact me if you need tech help. [email protected]
Jan 30, 2010 | Pc America Restaurant Pro Express
not knowing what the model is I suspect the machine suffered a power surge or got a spill
Aug 26, 2009 | Casio Parts Cash Register PC Desktop
129 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
