Question about Health & Beauty
Pride Sundance mobility scooter. Why does it stop without warning when I am in forward (or reverse)?
Batteries are charged and in good condition.
Posted by Arthur Locke on
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
Posted on Apr 03, 2009
Anonymous
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
gewiz
Rob Hill
  • 1421 Answers
SOURCE: PRIDE GOGO 3 WHEEL MOBILITY SCOOTER NOT USED FOR 3
sounds to me like the power controller pot located on the handlebar lever that you use to go forward and reverse ? , is there any up and down movement with this lever , if so that will be causing intermittant power delivery.
Posted on Jun 13, 2009
gewiz
Rob Hill
  • 1421 Answers
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Posted on Jun 14, 2009
Neil Wood
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
May 21, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Why does my scooter stick in reverse & wont go forward
Your wigwag pot sounds faulty you can very often buy a good used one on eBay
Apr 24, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
Why does my scooter stick in reverse when i push forward & stop when i push reverse
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Regards
Rob
www.gewizrepairs.co.uk
Apr 24, 2014 | Pride Mobility Products Pride Mobility...
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at [email protected] if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Apr 22, 2010 | Pride Mobility Products Celebrity X - 3...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Health & Beauty Logo
57 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
