Question about Radio Communications
I have a red Geneva radio and it has no lights showing today. I have it plugged in to the power and it doesn't seem to be charging. I am unable to turn it on.
I have had the radio for about 4 or 5 years now.
Posted by Maggie Hayes on
5 Related Answers
Anonymous
SOURCE: Won't piwer on
I pulled the manual, on page 13 it indicates if the red lamp light blinks, need to change the lamp light...it lasted almost a year with the ocassional slow start of lamp light blinking (perhaps 4-6 times), but the picture always came on within a couple of minutes, but now, picture will not come on....TV is about 4 yrs old also, exact same one you have....
Posted on Oct 03, 2007
Anonymous
SOURCE: My phone will not show it charging and will not turn on, red light flashing
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Posted on Jan 11, 2008
messiah220
  • 16 Answers
SOURCE: Dell Inspiron 5150 Will not turn on......
First off start with cheap, Replace the external powersupply, (the ac power cables and company)
Second, Replace the battery. However if it dosn't show the lights atall when it's plugged in it must not be the battery. Because even without the battery a light should come on saying the laptop is plugged in.
Finnaly what I think the problem probably consists of:
You most-likely need to get your computer repaired by someone, There's mostlikely a fault in the internal power supply. that charges the battery. I'm guessing maybe a little fuse or something popped and you need it replaced. But best get a professional to do it instead of someone who knows nothing.
Posted on Apr 29, 2009
Anonymous
  • 3 Answers
SOURCE: skullcandy double agent not charging
Make sure you have the memory card in the unit or it will not charge. If that doesn't work call up the company and ask for a refund/replacement.
Posted on Mar 31, 2010
Vinay Kumar
  • 438 Answers
SOURCE: Dell inspiron 1525 battery power light blinks
How old is the laptp? It seems that the battery has gone and needs a replacement. Please get a new one.
Posted on Feb 10, 2011
Light stays red after being plugged in for 24 hours
I am assuming that you are speaking of the charger. The Red LED shows that the charger is plugged into the wall. It does not show the charge status of the radio. These are very simple units, and it is not a "smart" charger.
Jul 29, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Rapoo H6060 red light doesn't go off
DUDE THIS SAME THING IS HAPPENING WITH ME BUT I BOUGHT IT YESTERDAY AND TODAY NIGHT IT SHOWS RED LIGHT CONTINUOUSLY! PLISS HELLP MEE
May 23, 2013 | Universal Rapoo H6060 Bluetooth 2.1EDR...
My Sloney E reader doesn't seem to be taking a
Because the battery is not removable? Best thing is to allow the E Reader to be completely cleared of any charge. OR While it is plugged in, press and hold the power and N buttons simultaneously for 20 seconds. I then turned the device on normally. Hope this help, have a great day..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Feb 24, 2012 | Sony Computers & Internet
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
New battery will not recharge
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
Dec 19, 2006 | QVS NetStar (UPS650A) UPS System
Radio Communications Logo
126 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
