Question about Shop Vac Vacuums
There is a float inside vacuum that will prevent the vacuum from sucking water if tank is full.
Posted on Jun 06, 2019
SOURCE: shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
Posted on Aug 29, 2007
SOURCE: after i cleaned the filter, shop vac doesn't turn back on
IT SOUND LIKE THE MOTOR WENT BAD OR IN SIDE THE PANLE A WIRE CAME LOSE
Posted on May 04, 2008
SOURCE: DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
Posted on Feb 26, 2009
SOURCE: Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
Posted on May 09, 2009
SOURCE: I have a 10 gallon Shop.Vac 3.0 but I don't have
Yes you should remove the filter for liquids. If the filter is not removed the internal float stop will not operate correctly. This will lead to the liquid being drawn up into the impeller and around the motor.
However I still like to have something in place because in most instances the liquid you vacuum up will not be without some solids. So I like to use a foam insert. Places like Home Depot carries a universal insert that works great.
Hope that helps.
Posted on Sep 17, 2009
Jun 02, 2018 | Vacuums
Jan 26, 2014 | Shop-Vac Products 850-02-10 - 850-Series...
Sep 30, 2013 | Shop Vac Vacuums
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Nov 29, 2009 | Vacuums
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Jun 19, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Nov 22, 2008 | Shop Vac Vacuums
Jul 26, 2019 | Shop Vac Vacuums
Dec 15, 2018 | Shop Vac Vacuums
116 people viewed this question
