Question about Radio Communications
What happened to little egg harbor n.j.and tuckerton n.j police scanner went quiet 5 or 6 days ago? change bands or what?
Posted by Steve Mathers on
1 Related Answer
n25an
Norman Davis
  • 622 Answers
SOURCE: scanner stuck on police band cannot change .Do not
do a google search for the manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 23, 2009
What is ment be reflashing a police scanner
  • When police, public safety, etc re-band then some scanners may not pick up the frequencies and you need to update the firmware (when available) to keep your scanners ability to monitor certain frequencies, pairs of frequencies, splinter channels etc.
  • Hope this helps.
Regards, Tony
Oct 17, 2011 | Radio Shack Pro-96 Scanner
Can you listen to a police frequency if it's trunked with this scanner? Uniden BC72xlt
You can listen to trunked police bands UNLESS: 1 they went Digital and your scanner is Analog. 2. They use an encrypted control frequency. 3. It is not against the law in your area. 4. you have a Trunked scanner. Following trunked frequencies requires a trunked scanner which is very different from regular everyday scanners. If the photo of your scanner is accurate then it appears you have Digital capability so that won't be a problem. You can go to Radio shack and purchase a book on Public Safety frequencies and Control Frequencies which will give you the proper frequency range but they will tell you nothing about Encryption on any Frequency. If you can not find a Control Frequency then you will not be able to track the hoping that is used in a trunked system. By the way, a Regular scanner runs about $50 where as a Trunked Scanner runs $150 to $200.
Oct 16, 2010 | Uniden BC72XLT Handheld Scanner
Motorola k7gt9500 police channel in manassas virginia?
Your Motorola radios operate in the FRS/GMRS band, which is at 462 MHz. Police, fire, EMS services, etc. operate in the 150 or 800 MHz bands. Your radios cannot receive public service transmissions, and they cannot be modified to do so. Monitoring public service transmissions will require a scanner.
For a comprehensive database of active frequencies and services in your area, visit:
www.RadioReference.com
For a good listing of available scanners, visit:
www.ScannerMaster.com
Jan 02, 2010 | Radio Communications
Pro96 PROBLEM
http://www.police-scanner.info/police-scanner-frequencies.htm you may need to put in the new freq. # a few months ago most went to new freq. #
Jun 14, 2009 | Radio Shack Pro-96 Scanner
Can't get Hopkinville police radio on my scanner
I know that most frequencys did change, I had the same problem when all the police went to digital, I had to put in new frequencys.
Mar 31, 2009 | Radio Shack Pro-83 Scanner
How can I program a Uniden scanner for the 849.0125-868.9875 MHz
you my live to far to pick it up, or a few months ago some police went digital and if yours has the your will need the new frequencys.
Mar 22, 2009 | Uniden BC278CLT Base Scanner
Radio Shack Pro Scanner
I know that if you turn your scanner off over a few days you can loose your frequency # or it will lock the channels out. if they or l/o just unlock then. I also know that all police and ect. went digital, you would to have a scanner that is digital. When they changed to digital some for the frequency # have changed. I had to get the new ones and put them in.
[email protected]
Jun 08, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Communications Logo
129 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
