Question about Sharp Computers & Internet
No power sharp mx5111
Turn on no display light stay orange
Posted by pam okopski on
2 Related Answers
greg_margo
Greg Margossian
  • 1959 Answers
SOURCE: Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Posted on Dec 16, 2009
SOURCE: will turn on but the
The steady orange light indicates that there is an error on the lamp of your projector. This is also the reason why it won't turn on.
• Ensure that the lamp cover is installed correctly.
• Check to see if the projector has overheated or the lamp usage exceeds 1100 hours (2100 hours in
Eco 2 mode and 1600 hours in Eco 1 mode). If there is insufficient ventilation around the projector or
if the room where you're presenting is particularly warm, move the projector to a cooler location.
The problem has to do with the lamp so have it checked.
Good luck.
Posted on Apr 22, 2011
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Vizio vp422 orange light stays on wont power up
I would double check the capacitors on the power supply board. Make sure you don't have any that are bulged at the tops. Secondly, when you try and turn it on, does the orange light flash at all??
Jan 20, 2013 | Vizio VP42-20A 42 in. Plasma TV
Power is on but after 2-4 seconds display turns off but power is still on where the power light is in blue.it's not in sleep mode where the power color is orange.it just goes back to normal at random...
Without looking at the monitor to confirm this, I suspect you have failing capacitors which power the HT circuit, simply, the power needed to light the display, is leaking to earth, capacitors have lost the ability to store the charge necessary to illuminate the screen, which is why it is working erratically.
You need to get this checked out by a TV technician.
Jul 23, 2011 | Acer Computers & Internet
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
Orange light will not stay on when the tv is off.
replace the power cord, do not use tv till you replace the power cord ok, you will eventually short circuit the tv or even worse blow the internal components
Jun 22, 2009 | Vizio L32 32 in. LCD HDTV
Sharp CRT that will not turn on
its CPU , please model TV write
Mar 17, 2009 | Sharp Televison & Video
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Computers & Internet Logo
Top Sharp Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ngoro
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
