Question about home Audio Players & Recorders
How to get 5.1 sound of pc in home cinema system
Posted by Chiranth Diganth on
5 Related Answers
Anonymous
  • 151 Answers
SOURCE: how to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 26, 2008
Anonymous
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
Anonymous
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
Anonymous
  • 7 Answers
SOURCE: no sound through my lg home cinema system when watching tiv
fiirst of all you should buy a converter..........which has a multiple use
Posted on Mar 04, 2009
Anonymous
  • 3 Answers
SOURCE: how can i listen to my tv through my cinema system
Use a fiber optic cable
Posted on Dec 27, 2009
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Configuring two soundcards for parallel functioning
a windows computer can only use one sound card for one function
you can use the internal sound card for output
you can use the usb sound card for input / recording.
you can't use both for both.
Start -> control panel -> sounds and audio devices properties
open up audio page
You can have one device selected on Sound playback
You can have one device selected on Sound recording.
you can change which sound card is used for which function on this page. if you want to use the internal sound card set both settings to the internal if you want to use the external change both settings to the external.
Jan 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Windows does not play nicely with 2 sound cards. Perhaps one of these days Microsoft will get out of the stone age and recognize other options, but for now, the general consensus is that it is not feasible.
About the only thing I have seen is to turn off one sound card in the hardware profile, but that is not what you are trying to do.
Jan 09, 2009 | ASUS VIA Apollo Pro Plus Chipset P2V-B...
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
How to hear sky tv's voice from home cinema system?
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
No sound through my lg home cinema system when watching tiv
Oct 30, 2007 | Samsung HT-X40 System
23 people viewed this question
Top home Audio Players & Recorders Experts
Kenneth Walker
Marvin
Marvin
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
