Is it genuine that you are having issues with Lexmark printer oversight code 108.xx? Do whatever it takes not to be startled. There are significantly more printer customers defying a comparable burden. We are here to outfit you with the clearest
Lexmark has placed an LED notification panel on the printers to allow the technical teams to easily
interpret the device's errors. The notification lights can indicate problems such as:
low ink toner level in the printer Life warning of the printer's Photo Conductor kit.
The ink cartridge errors in the printer Until the counter is replaced,
the printer will not print paper jamming. https://www.customersupportcare.com/lexmark-printer-support.html
You need of any our Technical Support agent. Please call Technical Support team at +1 888 597 3962 our experts are available 24/7 by phone.
SOURCE: Lexmark error codes
Too many to list here. Try justmanuals.com, you can get the service manual for about $10.
SOURCE: Lexmark x6100
Cartridge Error 50C
Your print cartridge has shorted.
If it does not repeat steps 1-3 and then go to step 7.
Good luck and dont forget to rate me!!!
SOURCE: Lexmark C510 Code error: 995 Service Engine Error
SOURCE: Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch. The first thing the we do (and have had great success with) is to clean the laser lenses. Then check the head wiring. The following codes apply:
106 & 110 CYAN
107 & 111 MAGENTA
108 & 112 YELLOW
109 & 113 BLACK
SOURCE: lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
