Question about Lexmark Office Equipment & Supplies
How do I fix Lexmark printer error code 1203?
Lexmark Printer Error code 994 and 993 essentially happen as a result of the failure of the cam sensors and can be viable fixed by our talented pros.
Posted by Sam Billings on
Jessica Davies
    Novelist:
    Scholar:
  • Lexmark Expert
  • 60 Answers
All in one Lexmark printers are durable and perform a lot of before printing the images or content. They scan, copy, and print those flawless documents quickly. Despite these features, you are likely to face Lexmark Printer Error Code 1203. This error indicates that the ink cartridge is affected and can slow down the printing process at once.
Reasons behind the Lexmark Error Code 1203
  • Lexmark printer Error may persist when the association between
  • A similar issue will persist if any of Lexmark ink cartridges do not respond
  • If the container does not contain the ink to print the pages, an alert message
  • There may be a failure of the hardware components.
  • The print will stop abruptly or slow down. The output will be different.
Methods To Resolve Lexmark Printer Error Code 1203
Steps:-1
First, you can switch off the printer and pull out the USB cords. Next keep aside the cartridge and wait for some time. Switch on the Lexmark printer again and see if the error pops up again.
Steps:-2
Remove the cartridge and clean it manually. Make sure you do it carefully and place it back to its correct position. Like the former method, turn on the Lexmark printer once you are done with the cleaning. Do not forget to close the print door once the procedure is over.
Contact us at Lexmark Printer Customer Service
If by following the steps, the error still occurs, you can contact us at Lexmark Printer Customer Service Number +1-866-231-0111 at anytime. We are having a highly skilled and trained team for the help of our clients. So feel free to reach us at anytime.
Posted on Jul 15, 2019
Jack Reacher
    Habit-Forming:
    Scholar:
  • 33 Answers
I would be happy to help you with this. However, I would need some information:
What is the printer model?
When do you see the error?
You need of any our Technical Support agent. Please call Technical Support team at +1 888 597 3962 our experts are available 24/7 by phone.
More Info - https://www.quickhelps.co/phone-number/lexmark/
Posted on Jun 06, 2019
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Posted on Aug 21, 2007
Ekse
  • 13434 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
Anonymous
  • 435 Answers
SOURCE: error 1203 Lexmark F4270
The 1203 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. The procedures in this article will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
click here for instructions).
Posted on Feb 14, 2009
Roop1980
Roopesh S
  • 228 Answers
SOURCE: Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Posted on May 23, 2009
Anonymous
SOURCE: lexmark all in one printer p6250 error code 1203
I HAVE AN ERROR CODE 1203
Posted on Sep 09, 2009
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
Error #1203
The 1203 error may be caused by a defective cartridge or a communication failure between one of the cartridges and the printer. Please visit the Lexmark website at http://bit.ly/aDUAjM for the troubleshooting steps. If the error continues, contact Lexmark technical support. Thank you for choosing Lexmark.
Oct 10, 2010 | Lexmark X5470 All-In-One InkJet Printer
Error #1203
The error indicates either a communication failure between the cartridges and the printer or by a short in one of the cartridges. Here's an article on Troubleshooting a 1203 Error Message on the Lexmark X5400 Series. Just click on this link: http://bit.ly/aDUAjM. Follow the instructions on the page. However, if the problem continues, I strongly suggest you contact Lexmark technical support for assistance. Thanks.
Aug 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
How to fix error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark printer problem. Printer is not printing shows error 1203
Hi
Error 1203 Dell 962
There can only try and I hope it will do the job for you.
or
press copy
you may need to Reset Factory Defaults
Mar 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
I receive code 1203 after changeing cartridge
Try the following link - http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
1. Enter your printer model
2. On the following page under "Search the KnowledgeBase" enter the text "error 1203"
3. From the results select "Troubleshooting a 1203 Error Message on the Lexmark X5450/X5470"
4. Follow the directions there and see if it solves your issue.
If not, you may want to try calling Lexmark Customer support.
Apr 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error code 1203
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
