SOURCE: blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
SOURCE: i need driver for hp 3005 dn
Check the support page below:
HP LaserJet P3005 Printer series - Download drivers and software
SOURCE: HP-LASERJET PRINTER PROBLEMS
Check one of the followings:
Paper jammed anywhere visible? Rollers, etc?
All the trays are closed properly?
Toner, Drum Unit or the Fuser Unit don't need changing?
See if you can print out the Printer Status of the Printer from it's menu which would give you some statistics of what needs to be replaced etc.
Contact your HP Dealer nearest you to fix that problem, it could still be under warranty so there'll be no added cost to you.
All the best!
ramatau
SOURCE: my HP laser jet 4250n printer turns on but the
Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
