Question about Health & Beauty
Scale was working this morning. Carried it against my body to bring it down stairs and now it doesn't turn on. Checked to make sure batteries didn't shift and they are in place. Any suggestions.
Posted by Joyce King on
5 Related Answers
Anonymous
  • 29 Answers
SOURCE: handle one siad keeps colapsing so unable to go down
you need to have your chassis repaired by www.buggypitstop.co.uk we repair and service bugaboos
Posted on Apr 29, 2010
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: recently bought a 2000 montero
For a battery to go dead on you like that there must be something draining the battery while the vehicle is switched off. It could be something like a trunk light which is not switching off or a short across some circuit that does not show up on any light. The first and easiest test is to disconnect the battery negative cable whenever you park the vehicle overnight etc. and see if the battery still runs down.
As a more positive step and if this does not affect the alarm, disconnect the positive lead from the battery and wire a bulb like a tail light bulb, between the terminal and the removed lead. The bulb should light up. Make sure that everything on the vehicle is switched off, the bulb should still be lit. Remove and replace the fuses one by one until the bulb goes out. That is the circuit that is running your battery flat. Check all the components on that circuit until you get the light to stay out and your problem should be found.
Posted on Feb 23, 2011
Harvey Hyde
  • 153 Answers
SOURCE: my car was running fine yesterday and this morning
Check for spark and fuel. When you turn the key on you should hear the fuel pump in the tank for a few seconds till the pressure builds up. When you crank the engine there should be spark at the plugs.
Posted on Jun 05, 2011
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: I bought a new scale,
Hi
Thank You for rejecting the session and down rating my assistance even though I tried to help you. That was an honest answer which off course you rejected...please post back for further assistance.
Daniel
Posted on Sep 15, 2011
czaa
Arnie Burke
  • 6576 Answers
SOURCE: after shifting into 3rd or
carb may be dirty causing stickin float or jets failin--chec ignition area-spark cables--coil etc --1st-----batt cud hav failed-old or not holdin charge--must be always @ 12.6v-a litttle lower and engine faulters
Posted on Sep 25, 2011
Taylor 7558 scale not working even with new batteries
the above answers are correct and need to be done but make sure the batteries are CR2032 and NOT CR2032E batteries. My Taylor 7901 scale finally works! Thanks for the advice. I love fixya.com because they always have the correct answers!!!!
Sep 12, 2012 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
I bought a new scale, but for some reason it doesn't work. I checked the battery and tried the scale on bathroom floor. It still doesn't work. What would you advice?
Hi
Daniel
Sep 15, 2011 | Conair Weight Watchers WW-87 Body Fat...
The Homedics SC 380 scale said low battery. After the battery (3V DL 2032) was replaced nothing works (does not turn on). Why would this happen? Is there a reset button or a button that turns it back on?
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
Jan 28, 2010 | Homedics Health & Beauty
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Body Fat Reading too high
Bring it back love..it's obviously ****..if u can not balance it out(usually there is a button) or reset the thing...bring it back and spend a lil bit more on something better..u seem serious about your body which is awesome so keep it up and replace the device
May 31, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
Health & Beauty Logo
229 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
