Question about Car Audio & Video
NDCN-W55 76027 screen goes blank when car start, stays black until car ignition is turned off, Can anyone help?
Model No: NDCN-W55 76027 insert correct map disk when the car ignition switch is on accessories. The audio keeps on working fine
Posted by zaidi_nh on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Posted on Dec 11, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
romsky79
rommel dadulla
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
Posted on May 28, 2009
Anonymous
SOURCE: 2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Posted on Jun 26, 2009
Anonymous
  • 8 Answers
SOURCE: I turn on my ps3 and the screen is black
Have You Pluged In The Yellow Video Cord All The Way?
Posted on Aug 14, 2009
Need help with blank TV screen after replacement of control panel
The new board may be causing this--either defective or the set needs a reset of some type---get the board from Samsung or where?
Jun 15, 2012 | Samsung LN40A500 LCD TV
Gopro hero screen is blank and the red light stays on
when you insert a battery into a hero3 or 3+ black model you must wait 4 seconds before trying to turn it on or it wont turn on until you remove the battery and then reinsert it while waiting 4 seconds to try and power it up:
Need a night vision or flat lens for your gopro contour or drift hd cameras?
RageCams Will Price Match & offer better custom tailored installation kits with their lenses to fill the gaps & hold focus which is very important. We offer more HQ lenses / replacement parts & have serviced more gopro cameras than anyone on the net & at the highest quality service available. Scratched your gopro lens or damage your led readout screen? We can replace it for you quickly or offer you the parts to do it yourself. HD Wearable Video Custom Mods By RageCams
May 25, 2012 | GoPro HD Motorsports HERO Camcorder
It doesnt turn on just the blue light on the wheel
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 29, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Ignition tumbler removal
There is a metal button on the ignition housing. Insert your key press the button while turning the key until the button goes in pull out the tumbler. Let me know if the helps. You need more help I will sent you step by step instructions. Hope that helped u out.
Jul 01, 2009 | 1997 Jeep Tj
VA930 LCD Screen goes black blank
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
If you need more help, let me know.
Apr 07, 2009 | ViewSonic VA1930WM LCD Monitor
Hi I have a 2006 chevy monte carlo ss. I left the key in the ignitin overnite. Today I went to start it and it wont turn over and the brake, shifter and all power is out on it. Can anyone help?
well i would deffinatly have the battery checked out because more than likly if you left the key in the on position the battery is dead let me know if this helps
Dec 29, 2008 | Chevrolet Monte Carlo Cars & Trucks
My nintendo light comes on but the screen stays blank
Clean the control deck and the cartridges. Check the input cable to the TV.
Hope this helped :)
Oct 26, 2008 | Nintendo 64 Console
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
