SOURCE: cant get google maps to work
Hello, Altrough I am not experienced with this particular model you may try the following method. First back up all your data on the internal memory of your device.This will allow you to restore contacts, programs or other data after you perform a master reset. Save the backup file to a memory card or another external storage device. Then hard reset the pda, to restore it to the factory settings. After this is done, install the program (google maps) after the pda's initial setup (wich occurs after the hard reset). Now check to see if the program works. If not, the logical assumtion would be that the program wasn't clearly designed for this pda model. Please notice that altrough all these devices run Palm OS, the actual operating system is different in order to fit each model's hardware specification. So it isn't like windows xp for example, wich can run on any computer, regardless of it's manufacturer or hardware components. If the program fails to work after all of this, you can either wait to see if google comes up with a patch to the program or a newer version that includes your pda in the suported devices list. Meanwhile you should use the backup you just made to restore the device to it's previus state. Please come back with a reply if this fails to work. Good luck.
SOURCE: ERROR: Error: Error calling method on NPObject!
you need to do a restore from the tomtom home software on your computer
SOURCE: Has anyone found a fix to this problem?
I'm still looking for a solution too.
720 connects to TT home another computer ok
in
chrome://tthome/content/ui/subtask/emulator/emulatorPage.js:232
Stack:
0.
function
startup_navigator("PB3378B01926","8-014-9372-3.framework","26","Latin-1","/Volumes/INTERNAL")
unknown
1. function ()
dataFolder);
SOURCE: When I try to operate my Go920:Error calling method on NPObject!
Did you find the solution? I am getting the same with my Go 730
