Question about Health & Beauty
My Heinger clipper keep cutting out while clipping even though they are fully charged
Posted by Sharon margarson on
5 Related Answers
Anonymous
SOURCE: Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Posted on Apr 01, 2009
Anonymous
SOURCE: Remington HC600 hair clipper stopped clipping
To all of you: adjusting the screws won't help, unless you screwed something up yourself, of course LOL The same problem bothered me a few years, and an hour ago I found out it could easily be a single hair stuck between the blades, thus separating them a bit. Get rid of it and the trimmer will probably work again. It can even get out spontaneously, which happened to me and kept me wondering what was going on.
P.S. DON'T lubricate unless you are required to (check your manual) The model I have (HC210c) does't need lubrication, I guess yours is similar to it. And remember that NOT every oily substance is a machine lubricant.
Posted on Jan 12, 2010
Thermo King
Thermo King
  • 593 Answers
SOURCE: my sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Posted on Jan 30, 2010
Anonymous
SOURCE: Hair Clippers not clipping
why do hair clipper pull hair instead of cutting
Posted on Jul 10, 2010
Anonymous
  • 81 Answers
SOURCE: phone keeps switching itself off even though the
phone need repair short in on off switch
Posted on Feb 03, 2011
How do I get my clippers to cut?
Try giving the blade an extra 1/2 a turn of tension, done by turning the red knob 1/2 a turn clockwise. It sounds as though the blades are jamming up which could be a lack of tension.
May 01, 2014 | Andis 68035 Progress Cattle And Horse Hair...
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
Blades wont cut. they are new, clean and appear to be in right.
if your blade is connected fully and the clipper is driving them then it sounds as though it may be a clipper fault without seeing them its hard to say what but the most likely is the Lever which wears in width.
May 28, 2011 | Blade Oster Cryogen X Agion A5 Clipper...
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Changing Blades
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Feb 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
try running the blade for a bit keep lubricating in between the blades its important to oil your blades during and after use to avoid rust build up on the cutting surfaces. Also just make sure the blade is engaging onto the clippers ok.
Sep 28, 2008 | Health & Beauty
Jun 28, 2007 | Remington HC-600 Hair Trimmer
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
