Question about Coleman Grilling
Coleman Roadtrip 9949 series regulator replacements not working
I have a Coleman roadtrip 9949 series. Movers lost the regulator. I've ordered the part 3x. One regulator said 9949 on box but had a 9928 sticker on it! Anyhow none of them worked. Gas goes from tank to regulator but not into bbq. Threading or pin wrong? Pls advise what other regulator I could use. Ps BBQ purchased in 2013, but has been in storage
Posted by April Flowers on
Andrew Taylor
    Top Expert:
  • Coleman Master
  • 32,277 Answers
Did the regulators have an emergency shut off valve, new ones do. It shuts the flow off if you connect and the gas taps are open. They would require resetting.
Coleman 9949 SERIES Parts ' BBQs and Gas Grills
https://www.appliancefactoryparts.com/gasgrillparts/coleman/9949-series.html
Buy Genuine BBQ and Gas Grill Parts for Coleman 9949 SERIES. ... Cooking Grids ' Covers ' Handles ' Hardware ' Hoses, Valves, and Regulators ' Igniters ' Knobs ' Other Parts ... 2000019875 - Pot Support Roadtrip® Accessory Stove Gr
Regulator Assembly ' Coleman
https://www.coleman.com/regulator-assembly/5010000743.html
Rating: 4.4 - ‎77 reviews
Purchase the Coleman regulator assembly for your Roadtrip grill. Choose from the array of Colemangrill parts available online.
Order direct from Coleman
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=sb_2XPHwEcbatQXjpq2ABw&q=coleman+roadtrip+9949+regulator
Posted on Jun 04, 2019
1 Related Answer
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: regulator pressure for a Coleman Roadtrip
Have you tried COLEMAN SPARES old chum?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 30, 2010
Problem starting coleman roadtrip grill 9941768
Make sure the igniter is not being covered in grease and not sparking. Also, if you had it stored, make sure a tiny critter has not taken up residence in one of the Gas tubes feeding the burner
Jun 13, 2014 | Coleman Roadtrip Grill LXE 9949-750
Coleman Roadtrip Grill+regulator and pipe freezes+flame surges
It sounds like too much pressure for the reg causing freezing or you have aleak on the line . possable you need to change reg .
May 13, 2012 | Coleman Roadtrip Grill LXE 9949-750
I have a Coleman Roadtrip XLE. The on/off knobs do not control the gas. The gas comes on FULL bore and give a LARGE flame.
The problem you're having could be the result of a faulty regulator. Replacing the Hose/Regulator Assembly should solve the problem. You can pick one up at any home center or hardware store that sell grills and accessories for about $30.00.
Hope this helped you and happy grilling. Thanks for choosing FixYa.
Aug 22, 2011 | Coleman Roadtrip Grill LXE 9949-750
My Coleman roadtrip cooks way too hot. Is there a way to turn down the flow. We are burnig on low.
If you're cooking at the lowest setting and the flames are to high, you will need to replace the gas control valve for the burners. Coleman still stocks some parts for your model. Appliance Factory Parts carries a wider selection of parts. http://www.appliancefactoryparts.com/
I hope this helps. Happy Grilling!!
Jul 14, 2011 | Coleman Roadtrip Grill LXE 9949-750
Cant find replacement burner any ideas
Try the Coleman web site, you chould be able to get one there.
Apr 09, 2010 | Coleman Roadtrip Grill LXE 9949-750
Grilling Logo
250 people viewed this question
Top Coleman Grilling Experts
Paul Carew
john h
Marvin
Marvin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
