When installing Agatha Christie And Then There Were none game for windows xp..when the game is a little over half way installed an you have to put the 2nd disk in an error message appears which reads: component-game files, file group- program executable files, file d:/data2.cab...Help would be appreciated.
Dont know this game - but if you log into mastertronics .com they might just be able to help or check game box as most of them come with a surport web page that should help you solve the problem.
3 poss.
your disc is dirty a simple clean will do,/ or has scratches on it where you will need to replace it.
/ your lens needs a clean / when this copy of this game was produced there was a fault wiyh the programe and should be replaced.
try cleaning disc & lens and failing that bring it back where you bought it and get them to replace it --- It dose happen...P.
that still doesnt work plz help!
Two things, make sure that the top and bottom of that 2nd disc is clean of fingerprints, smudges,etc. Then go ahead and try installing the game again, this time after you put the 2nd disc in, don't do anything and wait until the light on the cd drive goes off and then press a key to continue installing it and see how that goes.
